    MMM-Hotword (v2) - whole-new-built
    21 Posts 5 Posters 10.6k Views 5 Watching
    • ? Offline
      A Former User @smarthome
      @smarthome
      Well, hiding/revealing mechanism is only to call hide/show methods of target modules. During its hiding, what to be done or not will be the responsibility of that target module itself. If some module should be not working during hiding, it is the business of that module.
        smarthome @Guest
        @Sean
        Is there any “while…do” structure for using “hotword”, if have, we can do this lock function that temporary disable hotword
        for example, the hotword to work with MMM Assistant MK2 is “google”
        the hotword to lock is “lock_now”, the hotword to unlock is “hello123”
        hotword lock detect procedure is background running
        The structure is:
        while
        (("hotword lock detect procedure" )not equal to "lock_now" ) && ("hotword lock detect procedure" )not equal to "unlock_now" )
        do
        - setup hotword "google" to interactive  MMM Assistant MK2
        • ? Offline
          @smarthome
          In some modules of mine (MMM-Clap and MMM-GroveGestures…) have commandsMode or commandSet for different command sets by condition, but not this. I think it could be considerable for your needs. But anyway, I’m quite busy nowadays, so cannot support it immediately.
            smarthome @Guest
            @Sean
            Can I send double notificationExec to 2 Module with ony 1 hotword
            1st to MMM Page-Selector
            2nd to Assistant MK2 speaks about this action
            "open_news": {
            notificationExec: {
            notification: "PAGE_SELECT",
            payload:1
            notification: "ASSISTANT_SAY",
            payload:"Open News page"
            restart:true,
            Also combine
            "open_news": {
            				notificationExec: {
            					notification: {"PAGE_SELECT","ASSISTANT_SAY"}
            					payload:(1,"Open News page"}
            				restart:true,
            But in real test, only ASSISTANT_SAY can be executed
            How can I do that for both?
            Tks!
            • ? Offline
              @smarthome
              With only notificationExec of MMM-Hotword, you can send only one notification.
              There are 2 solutions.
              1. Use MMM-NotificationTrigger, it can fire several notifications at a time by one trigger.
              2. You can use moduleExec to call inner methods directly.
              moduleExec: {
                module: [],
                exec: (module) => {
                  if (module.name == "MMM-Page-Selector") {
                    module.notificationRecieved("PAGE_SELECT", 1)
                  if (module.name == "MMM-AssistantMk2") {
                    module.notificationRecieved("ASSISTANT_SAY", "Open News Page")
              (not tested code, but you can catch the concept. You can use sendNotification from sender module instead using notificationReceived of target module)
              PS AMK2 has some TTS-like feature(ASSISTANT_SAY) but I recommend you to use dedicated TTS modules like MMM-TTS or MMM-GoogleTTS.
                smarthome @Guest
                @Sean
                1/Could you give me the code in MMM Notification Trigger
                2/Your code with ModuleExec didn’t work
                3/I’m considering to use MMM TTS/Google TTS, but woud like to l try the simple solution first
                • ? Offline
                  @smarthome
                    module: "MMM-NotificationTrigger",
                      triggers:[
                          trigger: "PAGE_SELECT_1",
                          fires: [
                              fire: "PAGE_SELECT",
                              payload: (pl) => {return 1}
                              fire: "ASSISTANT_SAY",
                              payload: (pl) => {return "ASSISTANT_SAY"}
                  PAGE_SELECT_1 from notificationExec of Hotword.
                    smarthome @Guest
                    @Sean
                    Your notification code didn’t work. Nothing happen :(
                    Could you check it again, pls
                    payload: (payload) => { //OPTIONAL. transform received payload to what your target module wants.
                    You mean that: MMM Notification transform only, can not modify the payload then transform?
                    • ? Offline
                      @smarthome
                      Well, check the log. and tell me whether suspicious logs be there.
                      is equivalent to .sendNotification("PAGE_SELECT", 1). whatever pl would come, it will be transfomed(or modified, whatever you want to call) and the fired notification would have 1 as payload.
                        smarthome @Guest
                        @Sean
                        Finally, it worked, many thank for your help!
                        • 3 / 3
