    How do i fix this error??
    2 Posts 2 Posters 1.1k Views 2 Watching
    • K Offline
      KWuni
      I am not good in English. please refer to me.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
      Expected directory: electron-v3.0-linux-arm-glibc
      Found: [node-v64-linux-arm-glibc]
      This problem can often be fixed by running “npm rebuild” on the current system
      Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node’
      • ? Offline
        A Former User @KWuni
        @KWuni You need to do electron-rebuild. Read the instruction carefully.
