    Youtube autoplay
    6 Posts 3 Posters 3.8k Views 3 Watching
    • I
      ines
      I’ve update the mmm-assistantMk2 and suddenly when i demand a video from youtube it brings to me a video from youtube but the video doesn’t play
        sdetweil @ines
        @ines in the update MM uses an upgraded version of the browser that implements a new restriction, user must interact with screen before play is allowed…
        fix is to edit the MagicMirror/js/electron.js file and insert the line marked below (approx line 20)
        // Keep a global reference of the window object, if you don't, the window will
        // be closed automatically when the JavaScript object is garbage collected.
        let mainWindow;
        function createWindow() {
            app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
        	var electronOptionsDefaults = {
        then close and restart mm
        i see there is a proposed fix in the next update (July)
        Reply Quote 2
        • I
          ines
          Thank you a lot is works
          • A
            akshat
            If the youtube video is playing. How to stop it and go back to start screen?
              sdetweil @akshat
              @akshat what module is playing the YouTube video?
              • A
                akshat
                Using assistant-mk2. The problem is solved now. Thanks mate!
