    MMM-Hotword does not trigger MMM-AssistantMk2?
    7 Posts 3 Posters 2.3k Views 3 Watching
      ACRONN
      Hi all,
      I’ve been trying to set up MMM-Hotword and MMM-AssistantMk2 to my MagicMirror. I am successfully able to display the MMM-AssistantMk2 and MMM-Hotword icons on my mirror. It also registers the hotword (“Computer”) and then the microphone turns off and that’s it. That’s almost as far as I’ve gotten.
      After reading a few things, I also reinstalled both the Assistant & Hotword modules completely and then also added MMM-NotificationTrigger.
      I am able to get Hotword to pick up the microphone I am using with no problem, however as soon as I say my hot word “computer”, the microphone turns off, Hotword stops listening and Assistant does absolutely nothing.
      There must be something I’m missing because it seems to me that Hotword is either not being directed to Assistant or there are just some code errors involved.
      At one point I had hotword registering “computer”, then play a ding sound, then wrap back to monitoring for the hotword again.
      I have attached three files, my current MagicMirror config.js file, the command prompt output for the “npm start dev” and the console output in the dev start, which includes all errors including errors after I say my “computer” hot word where it stops listening directly after.
      Hardware and Software being used
      MagicMirror V2.7.1
      Raspbian Stretch V9.9
      Logitech Webcam C170
      MMM-Hotword V2.0.1
      MMM-AssistantMk2 V2.1.4
      MMM-NotificationTrigger, Last updated: 2018-10-02
      I have also attached the output of aplay and arecord -l:
      Any help would be appreciated
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "Aussie Holidays",
      						symbol: "calendar ",
      						url: "https://www.calendarlabs.com/ical-calendar/ics/35/Australia_Holidays.ics"
      //			module: "compliments",
      //			position: "lower_third"
      			module: "currentweather",
      				locationID: "1234567",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "1234567890abcdefghijlmnopqrstuvw"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "1234567",  //ID from https://openweathermap.org/city
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "ABC News",
      						url: "http://www.abc.net.au/news/feed/45910/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
            				module: "MMM-NotificationTrigger",
              				triggers:[
                  							trigger:"HOTWORD_DETECTED",
                  							fires: [
                      									fire:"HOTWORD_PAUSE",
                      									fire:"ASSISTANT_ACTIVATE",
      											//delay: 200,
                      									payload: function(payload) {
                        										return {
                          											"profile":payload.hotword
                  							trigger:"ASSISTANT_DEACTIVATED",
                  							fires: [
                      									fire:"HOTWORD_RESUME"
        				module: 'MMM-Hotword',
          					models: [
      								hotwords: "computer",
      								file: "/home/pi/MagicMirror/modules/MMM-Hotword/models/computer.umdl",
      								sensitivity: '0.5',
      					mic: {
              					recordProgram : "arecord",
              					device        : "plughw:1,0",
      						sampleRate    : 16000,
      						channels      : 1,
      						threshold     : 0.5,
        						thresholdStart: null,
        						thresholdEnd  : null,
        						silence       : 1.0,
      						verbose       : false,
          					autostart: true,              // if 'false', this module will wait for 'HOTWORD_RESUME' notification to start hotwords detection at the beginning.
          					autorestart: false,          // You can set this 'true' when you want this module to go back to listening mode automatically again after hotword is detected. But use this carefully when your other modules are using microphone or speaker.
            				module: "MMM-AssistantMk2",
            				position: "top_center",
      						record: {
                                      sampleRate    : 16000,
                                      channels      : 1,
                                      threshold     : 0.5,
                                      silence       : 1.0,
                                      verbose       : false,
      					deviceLocation: { // (OPTIONAL)
      						coordinates: { // set the latitude and longitude of the device (rf. mygeoposition.com)
      								latitude: -31.48,
      								longitude: 115.88,
      					defaultProfile: "default", // This default profile should be in `profiles` field.
      					profiles: 	{
      								"default" : 	{
      									profileFile: "/home/pi/MagicMirror/modules/MMM-AssistantMk2/profiles/default.json", //this path will be `~/MagicMirror/modules/MMM-AssistantMk2/profiles/default.json"
      									lang: "en-US",
      Dev Console Output
      main.js:454 Initializing MagicMirror.
      translator.js:201 Loading core translation file: translations/en.json
      translator.js:224 Loading core translation fallback file: translations/en.json
      loader.js:182 Load script: modules/default/alert//alert.js
      module.js:477 Module registered: alert
      loader.js:152 Bootstrapping module: alert
      loader.js:182 Load script: modules/default/alert/classie.js
      loader.js:182 Load script: modules/default/alert/modernizr.custom.js
      loader.js:182 Load script: modules/default/alert/notificationFx.js
      loader.js:157 Scripts loaded for: alert
      loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
      loader.js:197 Load stylesheet: vendor/css/font-awesome.css
      loader.js:159 Styles loaded for: alert
      translator.js:174 alert - Load translation fallback: translations/en.json
      /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:127 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
          protocols.This exposes users of this app to unnecessary security risks.
          Consider loading the following resources over HTTPS or FTPS.
       - http://localhost:8080/css/main.css
      - http://localhost:8080/fonts/roboto.css
      - http://localhost:8080/socket.io/socket.io.js
      - http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
      - http://localhost:8080/js/defaults.js
      - http://localhost:8080/config/config.js
      - http://localhost:8080/vendor/vendor.js
      - http://localhost:8080/modules/default/defaultmodules.js
      - http://localhost:8080/js/logger.js
      - http://localhost:8080/translations/translations.js
      - http://localhost:8080/js/translator.js
      - http://localhost:8080/js/class.js
      - http://localhost:8080/js/module.js
      - http://localhost:8080/js/loader.js
      - http://localhost:8080/js/socketclient.js
      - http://localhost:8080/js/main.js
      - http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
      - http://localhost:8080/translations/en.json
      - http://localhost:8080/modules/default/alert//alert.js
      - http://localhost:8080/modules/default/alert/classie.js
      - http://localhost:8080/modules/default/alert/modernizr.custom.js
      - http://localhost:8080/modules/default/alert/notificationFx.js
      - http://localhost:8080/modules/default/alert/ns-default.css
      - http://localhost:8080/vendor/css/font-awesome.css
      - http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
      - http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
       This warning will not show up
      once the app is packaged.
      warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:127
      /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:184 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
            Policy set or a policy with "unsafe-eval" enabled. This exposes users of
      warnAboutInsecureCSP @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:184
      loader.js:161 Translations loaded for: alert
      loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
      module.js:477 Module registered: updatenotification
      loader.js:152 Bootstrapping module: updatenotification
      loader.js:157 Scripts loaded for: updatenotification
      loader.js:159 Styles loaded for: updatenotification
      loader.js:161 Translations loaded for: updatenotification
      loader.js:182 Load script: modules/default/clock//clock.js
      module.js:477 Module registered: clock
      loader.js:152 Bootstrapping module: clock
      loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
      loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
      loader.js:157 Scripts loaded for: clock
      loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
      loader.js:159 Styles loaded for: clock
      loader.js:161 Translations loaded for: clock
      loader.js:182 Load script: modules/default/calendar//calendar.js
      module.js:477 Module registered: calendar
      loader.js:152 Bootstrapping module: calendar
      loader.js:237 File already loaded: moment.js
      loader.js:157 Scripts loaded for: calendar
      loader.js:197 Load stylesheet: modules/default/calendar/calendar.css
      loader.js:237 File already loaded: font-awesome.css
      loader.js:159 Styles loaded for: calendar
      loader.js:161 Translations loaded for: calendar
      loader.js:182 Load script: modules/default/currentweather//currentweather.js
      module.js:477 Module registered: currentweather
      loader.js:152 Bootstrapping module: currentweather
      loader.js:157 Scripts loaded for: currentweather
      loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
      loader.js:197 Load stylesheet: modules/default/currentweather/currentweather.css
      loader.js:159 Styles loaded for: currentweather
      loader.js:161 Translations loaded for: currentweather
      loader.js:182 Load script: modules/default/weatherforecast//weatherforecast.js
      module.js:477 Module registered: weatherforecast
      loader.js:152 Bootstrapping module: weatherforecast
      loader.js:157 Scripts loaded for: weatherforecast
      loader.js:237 File already loaded: weather-icons.css
      loader.js:197 Load stylesheet: modules/default/weatherforecast/weatherforecast.css
      loader.js:159 Styles loaded for: weatherforecast
      loader.js:161 Translations loaded for: weatherforecast
      loader.js:182 Load script: modules/default/newsfeed//newsfeed.js
      module.js:477 Module registered: newsfeed
      loader.js:152 Bootstrapping module: newsfeed
      loader.js:157 Scripts loaded for: newsfeed
      loader.js:159 Styles loaded for: newsfeed
      loader.js:161 Translations loaded for: newsfeed
      loader.js:182 Load script: modules/MMM-NotificationTrigger//MMM-NotificationTrigger.js
      module.js:477 Module registered: MMM-NotificationTrigger
      loader.js:152 Bootstrapping module: MMM-NotificationTrigger
      loader.js:157 Scripts loaded for: MMM-NotificationTrigger
      loader.js:159 Styles loaded for: MMM-NotificationTrigger
      loader.js:161 Translations loaded for: MMM-NotificationTrigger
      loader.js:182 Load script: modules/MMM-Hotword//MMM-Hotword.js
      module.js:477 Module registered: MMM-Hotword
      loader.js:152 Bootstrapping module: MMM-Hotword
      loader.js:182 Load script: https://code.iconify.design/1/1.0.2/iconify.min.js
      loader.js:157 Scripts loaded for: MMM-Hotword
      loader.js:197 Load stylesheet: modules/MMM-Hotword/MMM-Hotword.css
      loader.js:159 Styles loaded for: MMM-Hotword
      loader.js:161 Translations loaded for: MMM-Hotword
      loader.js:182 Load script: modules/MMM-AssistantMk2//MMM-AssistantMk2.js
      module.js:477 Module registered: MMM-AssistantMk2
      loader.js:152 Bootstrapping module: MMM-AssistantMk2
      loader.js:182 Load script: modules/MMM-AssistantMk2/vendor/serialize.js
      loader.js:157 Scripts loaded for: MMM-AssistantMk2
      loader.js:197 Load stylesheet: modules/MMM-AssistantMk2/MMM-AssistantMk2.css
      loader.js:159 Styles loaded for: MMM-AssistantMk2
      loader.js:161 Translations loaded for: MMM-AssistantMk2
      loader.js:197 Load stylesheet: css/custom.css
      :8080/modules/default/alert//alert.js:153 Starting module: alert
      :8080/modules/default/updatenotification//updatenotification.js:10 Start updatenotification
      :8080/modules/default/clock//clock.js:40 Starting module: clock
      calendar.js:74 Starting module: calendar
      currentweather.js:96 Starting module: currentweather
      weatherforecast.js:91 Starting module: weatherforecast
      newsfeed.js:59 Starting module: newsfeed
      main.js:472 All modules started!
      module.js:156 clock received a system notification: ALL_MODULES_STARTED
      module.js:156 calendar received a system notification: ALL_MODULES_STARTED
      newsfeed.js:344 newsfeed - received notification: ALL_MODULES_STARTED
      newsfeed.js:403 newsfeed - unknown notification, ignoring: ALL_MODULES_STARTED
      module.js:156 clock received a system notification: MODULE_DOM_CREATED
      module.js:156 calendar received a system notification: MODULE_DOM_CREATED
      newsfeed.js:344 newsfeed - received notification: MODULE_DOM_CREATED
      newsfeed.js:403 newsfeed - unknown notification, ignoring: MODULE_DOM_CREATED
      module.js:156 clock received a system notification: DOM_OBJECTS_CREATED
      module.js:156 calendar received a system notification: DOM_OBJECTS_CREATED
      newsfeed.js:344 newsfeed - received notification: DOM_OBJECTS_CREATED
      newsfeed.js:403 newsfeed - unknown notification, ignoring: DOM_OBJECTS_CREATED
      module.js:198 updatenotification is suspended.
      module.js:198 currentweather is suspended.
      module.js:198 weatherforecast is suspended.
      MMM-AssistantMk2.js:333 [AMK2]  YouTube iframe API is ready.
      module.js:205 currentweather is resumed.
      module.js:154 clock received a module notification: CURRENTWEATHER_DATA from sender: currentweather
      module.js:154 calendar received a module notification: CURRENTWEATHER_DATA from sender: currentweather
      newsfeed.js:344 newsfeed - received notification: CURRENTWEATHER_DATA
      newsfeed.js:403 newsfeed - unknown notification, ignoring: CURRENTWEATHER_DATA
      weatherforecast.js:279 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=2171507&units=metric&lang=en&APPID=7335b184ee7fbf412f7aa443e3938fb5 401 (Unauthorized)
      updateWeather @ weatherforecast.js:279
      (anonymous) @ weatherforecast.js:400
      weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
      weatherRequest.onreadystatechange @ weatherforecast.js:266
      XMLHttpRequest.send (async)
      MMM-Hotword.js:249 Uncaught TypeError: Cannot set property 'innerHTML' of null
          at Class.status (MMM-Hotword.js:249)
          at Class.socketNotificationReceived (MMM-Hotword.js:149)
          at module.js:246
          at r.<anonymous> (socketclient.js:25)
          at r.emit (index.js:83)
          at r.onevent (index.js:83)
          at r.MMSocket.self.socket.onevent (socketclient.js:19)
          at r.onpacket (index.js:83)
          at r.<anonymous> (index.js:83)
      status @ MMM-Hotword.js:249
      socketNotificationReceived @ MMM-Hotword.js:149
      (anonymous) @ module.js:246
      (anonymous) @ socketclient.js:25
      r.emit @ index.js:83
      r.onevent @ index.js:83
      MMSocket.self.socket.onevent @ socketclient.js:19
      r.onpacket @ index.js:83
      (anonymous) @ index.js:83
      r.ondecoded @ index.js:83
      a.add @ index.js:83
      r.ondata @ index.js:83
      r.onPacket @ index.js:83
      r.onData @ index.js:83
      ws.onmessage @ index.js:83
      module.js:154 clock received a module notification: HOTWORD_LISTENING from sender: MMM-Hotword
      module.js:154 calendar received a module notification: HOTWORD_LISTENING from sender: MMM-Hotword
      newsfeed.js:344 newsfeed - received notification: HOTWORD_LISTENING
      newsfeed.js:403 newsfeed - unknown notification, ignoring: HOTWORD_LISTENING
      module.js:154 clock received a module notification: CALENDAR_EVENTS from sender: calendar
      newsfeed.js:344 newsfeed - received notification: CALENDAR_EVENTS
      newsfeed.js:403 newsfeed - unknown notification, ignoring: CALENDAR_EVENTS
      module.js:205 weatherforecast is resumed.
      MMM-Hotword.js:254 Uncaught TypeError: Cannot set property 'className' of null
          at Class.status (MMM-Hotword.js:254)
          at module.js:246
      status @ MMM-Hotword.js:254
      a.add @ index.js:83
      MMM-Hotword.js:199 Uncaught TypeError: Cannot read property 'play' of null
          at Class.playBeep (MMM-Hotword.js:199)
          at Class.socketNotificationReceived (MMM-Hotword.js:156)
          at module.js:246
      playBeep @ MMM-Hotword.js:199
      socketNotificationReceived @ MMM-Hotword.js:156
      a.add @ index.js:83
      module.js:154 clock received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
      module.js:154 calendar received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
      newsfeed.js:344 newsfeed - received notification: HOTWORD_SLEEPING
      newsfeed.js:403 newsfeed - unknown notification, ignoring: HOTWORD_SLEEPING
      MMM-Hotword.js:261 Uncaught TypeError: Cannot set property 'className' of null
          at Class.status (MMM-Hotword.js:261)
          at Class.socketNotificationReceived (MMM-Hotword.js:170)
          at module.js:246
      status @ MMM-Hotword.js:261
      socketNotificationReceived @ MMM-Hotword.js:170
      a.add @ index.js:83
      Dev Command Prompt Output
      pi@raspberrypi:~/MagicMirror/config $ npm start dev
      > magicmirror@2.7.1 start /home/pi/MagicMirror
      > sh run-start.sh "dev"
      Starting MagicMirror: v2.7.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-NotificationTrigger
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-AssistantMk2
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-NotificationTrigger
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-AssistantMk2
      Launching application.
      Create new calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/35/Australia_Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.abc.net.au/news/feed/45910/rss.xml - Interval: 300000
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [AMK2] Temporal storage directory is clearing.
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [HOTWORD] Detected: computer
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: true, hotword: 'computer', file: null }
      Use existing news fetcher for url: http://www.abc.net.au/news/feed/45910/rss.xml
      [HOTWORD] begins.
      [HOTWORD] stops.
      [HOTWORD] begins.
      [HOTWORD] stops.
      • ? Offline
        A Former User @ACRONN
        @ACRONN
        your hotword configuration is not matched to current version. and you dont need notificationtrigger for basic usage.
          sdetweil
          @ACRONN said in MMM-Hotword does not trigger MMM-AssistantMk2?:
          MMM-Hotword.js:249 Uncaught TypeError: Cannot set property ‘innerHTML’ of null
          hotword had an error. and so will not be working.
            ACRONN @Guest
            @Sean
            Thank you
            Could you point me to a sample configuration that will work with Hotword and Assistant Mk2? I will also remove Notification Trigger.
            • ? Offline
              @ACRONN
              https://github.com/eouia/MMM-Hotword/blob/master/documents/config.md#simple-configuration-example
                ACRONN
                I initially tried that but I will try it again as per your advice
                  ACRONN @Guest
                  @Sean
                  Hi Sean
                  Post a rebuild and using the original config.js it now works ie hotword now correctly calls assistant. The only issue left is when google presents me with options it doesn’t then listen for a follow up selection and throws back to hotword again. Is there a setting to enable assistant to follow up and finish the assistant sequence? Thx
