    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    SOLVED "MMM-BackgroundSlideshow" the path to the image in the USB folder?
    Troubleshooting
    • P
      prism last edited by
      If I update the image frequently, is there a way to save the path to the image in the USB folder?
        sdetweil @prism last edited by sdetweil
        @prism you will have to make a link from the module folder to the USB folder, then it will work…
        the MM web server root is the MagicMirror/modules folder
        see the ln command
        • P
          prism @sdetweil last edited by
          Can you explain in detail? I’ve modified the path in ‘config.js’ and the module ‘MMM-BackgroundSlideshow.js’, but it does not recognize it.
          Grace to the elderly who are not familiar with computers …
          Wait for your detailed reply.
            @prism who u calling elderly!. I am 68 in 2 weeks…lol!
            the link (ln) command provides for a local folder (or ) file, actually being someplace else
            so,
            ln -s "the usb folder" "some_new_directory in the MMM-BackgroundSlideshow folder"
            then config the module to show images from the “some_new_directory in the MMM-BackgroundSlideshow folder”
            in my case
            lrwxrwxrwx  1 odroid odroid   18 Apr 29 12:40 uploads -> /media/odroid/misc/
            uploads (here) points to my external disk shared over the network and mounted at /media/odroid/misc
            so my commands were
            cd MagicMirror/modules/MMM-ImageSlideShow
            ln -s /media/odroid/misc uploads
            • P
              Thank you.
              Thanks to you, I was able to work without any problems.
              Thank you again for your kindness.
                @prism great!.. can u mark this is resolved…
