    Resize middle center region
    3 Posts 3 Posters 1.8k Views 5 Watching
      dcarls91
      Hello I am currently trying to place MMM-SmartWebDisplay in the middle center of my mirror. I adjusted the width via the config.js file. However, I am unable to make the module any taller than the formatted size of the middle center bar. I am wondering if this is something I have to do from the custom .js file as well as do I resize the region or actual module. Also, I am still learning the css so any help would be greatly appreciated. Thanks
        JJTechman68
        Did you ever find a solution? I have the same problem.
          sdetweil @dcarls91
          @dcarls91 i think you could override the regions sizings in custom.css
          this is whats in main.css for the center
          .region.third,
          .region.middle.center {
            width: 100%;
            text-align: center;
            transform: translateY(-50%);
          .region.upper.third {
            top: 33%;
            top: 50%;
          .region.lower.third {
            top: 66%;
          and index.html (spaces after < because the viewer here does some funny stuff)
                  < div class="region upper third">< div class="container">< /div>< /div>
          	< div class="region middle center">< div class="container">< /div>< /div>
          	< div class="region lower third">< div class="container"><br/>< /div>< /div>
          so, if u make upper a little smaller and middle a little bigger… it might work out
