Problems with Config.js on Pi4 BlackScreen
24 Posts 2 Posters 6.3k Views 2 Watching
    dazza120 @sdetweil
    @sdetweil still nothing in the dev console mate, i can start the whole build over again but everytime i go to change the config it doesnt work
    S 1 Reply Last reply Jul 13, 2019, 6:34 PM Reply Quote 0
      sdetweil @dazza120
      @dazza120 ok, start again… change the config?
      So, you install a module. If it has package.json file you run npm install in the module folder
      Then edit config.js and add
      Module structure.
        module:'somename',
      To the modules array.
      If think syntax error, from the MagicMirror folder do,
      npm  run config:check
      D 2 Replies Last reply Jul 13, 2019, 6:56 PM Reply Quote 0
        dazza120 @sdetweil
        @sdetweil yep im cd-ing into the module folder and then running npm install, ill start over again and go through it slowly but ive probably built the mirror 20 from scratch no issues before with config but ive altered it too much now thinking that was it so its from scratch now but copying back the old config should have sorted any of those issues, does your installer work?
          dazza120 @sdetweil
          @sdetweil I think i found the problem mmm-nest-status install messes up the MM install, i think other are having simular things with other modules. i installed MMM-SystemStats changed the config file tested it and it was working find, i installed mmm-nest-status and didn’t alter the config for that so that should have just ment it wouldn’t run that module. i have attached the code below does this shead any light?
          pi@raspberrypi:~ $ cd MagicMirror/modules
          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/BenRoe/MMM-SystemStats
          Cloning into 'MMM-SystemStats'...
          remote: Enumerating objects: 22, done.
          remote: Counting objects: 100% (22/22), done.
          remote: Compressing objects: 100% (14/14), done.
          remote: Total 231 (delta 10), reused 16 (delta 8), pack-reused 209
          Receiving objects: 100% (231/231), 88.08 KiB | 578.00 KiB/s, done.
          Resolving deltas: 100% (122/122), done.
          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-SystemStats
          pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ npm install
          npm notice created a lockfile as package-lock.json. You should commit this file.
          added 1 package from 1 contributor and audited 1 package in 1.265s
          found 0 vulnerabilities
          pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ cd
          pi@raspberrypi:~/MagicMirror $ npm  run config:check
          > magicmirror@2.8.0 config:check /home/pi/MagicMirror
          > node tests/configs/check_config.js
          Checking file...  /home/pi/MagicMirror/config/config.js
          Your configuration file doesn't contain syntax errors :)
          pi@raspberrypi:~/MagicMirror $ cd modules
          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/michael5r/mmm-nest-status.git
          Cloning into 'mmm-nest-status'...
          remote: Enumerating objects: 135, done.
          remote: Total 135 (delta 0), reused 0 (delta 0), pack-reused 135
          Receiving objects: 100% (135/135), 65.27 KiB | 718.00 KiB/s, done.
          Resolving deltas: 100% (77/77), done.
          pi@raspberrypi:~/MagicMirror/modules $ cd mmm-nest-status
          pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ npm install
          npm WARN deprecated undefined@0.1.0: this package has been deprecated
          npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
          npm WARN modules No description
          npm WARN modules No repository field.
          npm WARN modules No README data
          npm WARN modules No license field.
          removed 1 package in 1.141s
          pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ cd
          pi@raspberrypi:~ $ pm2 restart MagicMirror
          Use --update-env to update environment variables
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
          [PM2] [MagicMirror](0) ✓
          │ Name        │ id │ mode │ status │ ↺ │ cpu │ memory   │
          │ MagicMirror │ 0  │ fork │ online │ 2 │ 0%  │ 2.5 MB   │
           Use `pm2 show <id|name>` to get more details about an app
          pi@raspberrypi:~ $ npm  run config:check
          npm ERR! path /home/pi/package.json
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/.npm/_logs/2019-07-13T20_08_21_703Z-debug.log
          pi@raspberrypi:~ $
          Complete log from .npm folder
          1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'run', 'config:check' ]
          2 info using npm@6.10.1
          3 info using node@v10.15.2
          4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
          5 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json'
          6 verbose cwd /home/pi
          7 verbose Linux 4.19.57-v7l+
          8 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "run" "config:check"
          9 verbose node v10.15.2
          10 verbose npm  v6.10.1
          11 error path /home/pi/package.json
          12 error code ENOENT
          13 error errno -2
          14 error syscall open
          15 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          16 error enoent This is related to npm not being able to find a file.
          17 verbose exit [ -2, true ]
          • 3 / 3
          3 / 3
