    Can't access to https server with clientonly
    1 Posts 1 Posters 532 Views 1 Watching
    • I Offline
      ibob
      Hi all,
      It seems to be impossible to connect to a https server when using clientonly.
      First of all, in line 64 in /serveronly/index.js, we can see
      getServerConfig(`http://${config.address}:${config.port}/config/`)
      with no use of https
      Once I have modified the line with https, i encounter another error message
      Unable to connect to server: (Error: Unable to read config from server (https://xxxx:8080/config/ (unable to verify the first certificate)
      I can access to the server with no problem using a browser.
      Any idea?
      Thank you very much
