    Calendar module shows only today's appointments
    5 Posts 2 Posters 2.1k Views 2 Watching
    • C Offline
      castletonroad
      This problem has only started since I upgraded MagicMirror to v2.8.0.
      I have three calendars on display, each showing ?export calendars from Nextcloud CalDAV server.
      One of the calendars has daily/repeating entries.
      In the morning, it shows all upcoming events for the day.
      By the end of the day, and as the events occur, there are ‘No upcoming events’.
      Next morning, that day’s events show.
      The behavior before the upgrade to v2.8.0 used to be a rolling 8 events, so the calendar always showed 8 events, and by the evening, it was tomorrow’s 8 events that were showing.
      This is a strange behavior, which I have tried my best to explain.
      I really hope this sounds familiar to someone, and that they can help…
      Thanks very much :)
        sdetweil @castletonroad
        @castletonroad there seems to be a regression with repeating calendar events.
        No fix reported yet
        • C Offline
          castletonroad @sdetweil
          Thanks very much for the reply.
          Is it with the current version then, as i) things used to work fine before v2.8.0, and ii) it worked fin also with links to Google ics calendars…?
            @castletonroad yes, w 2.8.0
            Reverting to 2.7.1 it works
            • C Offline
              Thanks Sam, I’ll mark this as solved.
