    Default calendar shows no items when a series is in the calendar
    2 Posts 2 Posters 497 Views 2 Watching
    • I Offline
      iceythegreatest
      Dear,
      i am using MM version 2.8.0 with the default calendar. Because the module is not able to get my caldav directly i download it via curl into a locally file and in the config of the calendar i am just pointing to the local caldav like this:
      			header: "Chaoskalender",
      					colored: false,
      					coloredSymbolOnly: false,
      					url: "http://127.0.0.1:8080/modules/calendars/chaos.ics",
      					symbol: "calendar",
      Works good so far BUT as soon as i create a series of events i get following error messages:
      No toISOString function in curr.start 00)":20190909T164500
      TypeError: event.start.getFullYear is not a function
          at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:270:33
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:18:4)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
          at Request.emit (events.js:189:13)
          at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1161:10)
          at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1083:12)
          at Object.onceWrapper (events.js:277:13)
          at IncomingMessage.emit (events.js:194:15)
          at endReadableNT (_stream_readable.js:1103:12)
      In outlook, on the iphone or even in the groupware it is displayed perfectly without any issues.
      So if anyone has an idea or solution to fix this issue i would be very glad in getting help here because i don´t have any ideas anymore.
      Thanks in advance
      icey
        sdetweil @iceythegreatest
        @iceythegreatest
        looks like the caldav to ics doesn’t produce the info in the format the latest code expects. (ISOStrings)
        i think this is another bug. I suggest you open an issue on github for MagicMirror so someone can look at it eventually. (This is all volunteer, and anyone can propose a fix)
        comment in calendarfetcher.js is
        // ical.js started returning recurrences and exdates as ISOStrings without time information.
