    Need some help getting AlexaOnOff to work with Google Mini
    2 Posts 1 Posters 889 Views 1 Watching
      smackenzie5
      @shbatm
      I’m including the following folks in this post since, at some point in the forum, they have all asked how to get AlexaOnOff working with Google Home @eddgeywing @retroflex @selarp @felipemfa
      If any of you have already gotten Google to work with AlexOnOff, please share.
      @shbatm in previous posts you asked for the following info so here it is:
      1. My mirror version is 2.7.1. My understanding is I don’t need to change line 21 in MMM-AlexaOnOff to match this number.
      2. “FauxMo service started. Listening on 192.168.1.32:21900” is listed – see below.
      3. Tested with example but got similar results as original – see below.
      4. Even tried discovery from alexa.amazon.com but unable to register for account since I don’t have an echo – yes, I’m desperate…
      Here is the code for my config.js – should be same as yours:
          			module: 'MMM-OnScreenMenu',
          			position: 'bottom_right',
          			module: 'MMM-AlexaOnOff',
              			devices: [{
                    			on: {
                      			notification: "ONSCREENMENU_PROCESS_ACTION",
                      			payload: { actionName:'monitorOn' }
                    			off: {
                      			payload: { actionName:'monitorOff' }
      Here is what I get when I start MagicMirror:
      pi@raspberrypi:~ $ cd MagicMirror
      pi@raspberrypi:~/MagicMirror $ sudo npm start
      > magicmirror@2.7.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.7.1
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-google-route.
      Module helper loaded: MMM-OnScreenMenu
      Module helper loaded: MMM-AlexaOnOff
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-OnScreenMenu
      Connecting socket for: MMM-AlexaOnOff
      Module helper started for MMM-AlexaOnOff
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxx/basic.ics - Interval: 300000
      21900
      Here is the sudo netstat -tulpn:
      pi@raspberrypi:~ $ sudo netstat -tulpn
      Active Internet connections (only servers)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
      tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      3081/electron
      tcp        0      0 0.0.0.0:21900           0.0.0.0:*               LISTEN      3081/electron
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           3081/electron
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           307/dhcpcd
      udp        0      0 0.0.0.0:56022           0.0.0.0:*                           335/avahi-daemon: r
      udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1334/libpepflashpla
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           335/avahi-daemon: r
      udp6       0      0 :::55455                :::*                                335/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                335/avahi-daemon: r
      pi@raspberrypi:~ $
      And starting the example:
      pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-AlexaOnOff/node_modules/fauxmojs/example
      pi@raspberrypi:~/MagicMirror/modules/MMM-AlexaOnOff/node_modules/fauxmojs/example $     node example.js
      started..
      And the sudo netstat -tulpn for the example:
      tcp        0      0 0.0.0.0:11000           0.0.0.0:*               LISTEN      3634/node
      tcp        0      0 0.0.0.0:11001           0.0.0.0:*               LISTEN      3634/node
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           3634/node
      pi@raspberrypi:~ $
      Switching gears –
      I started looking at the Belkin website for how to connect Wemo to Google:
      https://www.belkin.com/us/support-article?articlenum=224185
      The article basically says that you have to setup your Wemo device before Google can find it. In order to setup your Wemo device, you have to select it from your wifi menu:
      https://www.belkin.com/us/support-article?articlenum=110936
      After running Mirror (and same with example), I tried setting up Wemo but I’m not able to see the faux Wemo switch or devices on my wifi.
      Is the faux Wemo discoverable under wifi as the article directs?
      Another option Belkin describes is entering the MAC address.
      Is there a MAC address for the faux Wemo switch?
      I know that’s a lot of stuff to go through but I’ve been working on this for a while.
      I really want to get this working. Without it, my mirror is pretty much useless.
      I’m going to use AlexaOnOff with OnScreenMenu to turn the monitor on and off only (BTW – OnScreenMenu works great, thanks).
      Any help with AlexaOnOff would be appreciated.
      Thanks,
      Scott
        smackenzie5 @smackenzie5
        @smackenzie5 said in Need some help getting AlexaOnOff to work with Google Mini:
        @shbatm
        @shbatm
        According to this article, Google home runs port 80:
        https://github.com/makermusings/fauxmo/issues/21
        Don’t know if that would make a difference?
