    MMM-MMM-Remote-Control monitor problem
    3 Posts 2 Posters 1.4k Views 2 Watching
    • O Offline
      off112
      I can’t turn on my monitor after I upgraded to debian buster.
      I tried to change the node_helper.js to:
      let monitorOnCommand = (this.initialized && "monitorOnCommand" in this.thisConfig.customCommand) ?
                      this.thisConfig.customCommand.monitorOnCommand :
                      "vcgencmd display_power 1";
                  let monitorOffCommand = (this.initialized && "monitorOffCommand" in this.thisConfig.customCommand) ?
                      this.thisConfig.customCommand.monitorOffCommand :
                      "vcgencmd display_power 0";
                  let monitorStatusCommand = (this.initialized && "monitorStatusCommand" in this.thisConfig.customCommand) ?
                      this.thisConfig.customCommand.monitorStatusCommand :
                      "tvservice --status";
      But I can only turn off the monitor, not turn it on again. Is there a fix to this problem?
        sdetweil
        Does this work from command line (via ssh with screen off)
        • O Offline
          off112
          For some reason it started to work.
          But I’m not sure how to do to get the monitor status to work.
          I have tried to make these changes. But it doesn’t work:
            monitorControl: function(action, opts, res) {
                      let status = "unknown";
                          "vcgencmd display_power";
                      if (["MONITORTOGGLE", "MONITORSTATUS", "MONITORON"].indexOf(action) !== -1) {
                          screenStatus = exec(monitorStatusCommand, opts, (error, stdout, stderr) => {
                              if (stdout.indexOf("display_power=0") !== -1 || stdout.indexOf("0") !== -1) {
                                  // Screen is OFF, turn it ON
                                  status = "off";
                                  if (action === "MONITORTOGGLE" || action === "MONITORON") {
                                      exec(monitorOnCommand, opts, (error, stdout, stderr) => {
                                          this.checkForExecError(error, stdout, stderr, res, { monitor: "on" });
                                      this.sendSocketNotification("USER_PRESENCE", true);
                                      return;
                              } else if (stdout.indexOf("HDMI") !== -1 || stdout.indexOf("true") !== -1) {
                                  // Screen is ON, turn it OFF
                                  status = "on";
                                  if (action === "MONITORTOGGLE") {
                                      this.monitorControl("MONITOROFF", opts, res);
                                      return;
                              this.checkForExecError(error, stdout, stderr, res, { monitor: status });
                              return;
