    MMM-CalendarExt not showing up at all
    6 Posts 3 Posters 1.4k Views 3 Watching
    • T Offline
      tomXGames
      Hi!
      I’ve been trying for about two hours to get this module to show up, but I can’t get it to do that. The only thing I see is the header. Here’s my config.js:
            			module: "MMM-CalendarExt",
      			header: "Kalender",
              		system: {
                				show: ["daily", "upcoming"],
                				locale: 'de',
                				redrawInterval:60000,
              			views: {
                				daily: {
                  						position:'bottom_bar',
                  						counts:7,
                				upcoming: {
                  						position:'top_left',
                  						limit:5
              			defaultCalendar: {
                						maxEntries:50,
                						maxDays:180,
                						interval: 1000*60*5,
              			calendars :[
                  						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      And here’s a screenshot of what I see:
      Can anyone help me, please?
      Thanks a lot,
      tomX
      • F Offline
        Fr8Trayne
        Have you tried using his MMM-CalendarExt2 module? I found it much easier to use. Super quick and easy to implement.
        • ? Offline
          A Former User @tomXGames
          @tomXGames
          With my test, there is no problem at all.
          What is shown on your log file? It should be like this;
          Possible issues;
          • You might have some errors from other modules. Some errors could interrupt other module’s working.
          • Using some kind of page changer or showing/hiding modules on bootup. (are you using?)
          • T Offline
            tomXGames @Guest
            @Fr8Trayne Thanks, but I really need the multiple users to have separate calendars (from my understanding, that’s not possible with MMM-CalendarExt2).
            @Sean Thanks for your input! I only use the builtin modules, plus MMM-ProfileSwitcher. And my log looks like this:
            Connecting socket for: MMM-CalendarExt
            Starting module: newsfeed
            { Error: listen EADDRINUSE 127.0.0.1:8080
                at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                at listenInCluster (net.js:1378:12)
                at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
              errno: 'EADDRINUSE',
              code: 'EADDRINUSE',
              syscall: 'listen',
              address: '127.0.0.1',
              port: 8080 }
            Launching application.
            It’s obviously connected to the internet. I also looked at what is running on port 8080, but it seems that electron is running there, so I see no problem…
            Thanks,
            tomXGames
            • ? Offline
              @tomXGames said in MMM-CalendarExt not showing up at all:
              1. You can assign the scene for specific user. Each scene could be changed by definable notification. It means, if you can send proper notification from other module, MMM-CalendarExt2 can change it’s dedicated scene.
              You probably executed MM twice. (Or your previous MM was not killed normally) Check your pm2.
              • T Offline
                tomXGames @Guest
                @Sean said in MMM-CalendarExt not showing up at all:
                That was it thanks.
