    record.start is not a function at GoogleAssistant,startConversation TypeError
    2 Posts 2 Posters 830 Views 2 Watching
    • ? Offline
      [[global:former-user]]
      > magicmirror@2.9.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-AirQuality.
      Module helper loaded: MMM-NotificationTrigger
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-AssistantMk2
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-NotificationTrigger
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-AssistantMk2
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/ko.south_korea%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
      Create new news fetcher for url: http://fs.jtbc.joins.com/RSS/newsflash.xml - Interval: 300000
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [AMK2] Temporal storage directory is clearing.
      [AMK2] assistant ready
      [AMK2] Conversation starts.
      [AMK2] Started with text query: brief today
      { requestId: '' } { profileFile: 'default.json', lang: 'ko-KR' }
      [AMK2] Device Action: { requestId: '' }
      [AMK2] Assistant Text Response:
      [AMK2] Conversation Completed
      TypeError: record.start is not a function
         at GoogleAssistant.startConversation (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:393:26)
         at GoogleAssistant.emit (events.js:182:13)
         at GoogleAssistant.start (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/index.js:38:10)
         at GoogleAssistant.assistant.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:413:17)
         at Auth.GoogleAssistant.auth.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/index.js:25:10)
         at Auth.emit (events.js:182:13)
         at saveTokens (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/auth.js:32:10)
         at Auth.process.nextTick (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/auth.js:92:35)
         at process._tickCallback (internal/process/next_tick.js:61:11)
      [HOTWORD] Detected: smart_mirror
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: true, hotword: 'smart_mirror', file: null }
      [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
         at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
         at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
         at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
         at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
         at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
         at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
         at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
       code: 14,
       metadata:
        Metadata { _internal_repr: { 'content-disposition': [Array] }, flags: 0 },
       details: 'Service unavailable.' }
      [HOTWORD] begins.
      Shutting down server...
      Stopping module helper: calendar
      Stopping module helper: newsfeed
      Stopping module helper: MMM-NotificationTrigger
      Stopping module helper: MMM-Hotword
      Stopping module helper: MMM-AssistantMk2
      how can I solve this problem??
        sdetweil @Guest
        @kai I think @Sean will need to look at this problem… he is the Module author…
        I thnk u need to open an issue on the github site for this module.
        attach this content to the issue
