    MMM-Face-Reco-DNN doesn't work
    mmm-face-reco-dnnconfig.jsopencv
    16 Posts 3 Posters 6.1k Views 3 Watching
      Antagonist
      Everything works fine without the module integration in the MagicMirror/config.js but with the additional text there is no response and the monitor is black. I installed python in a virtual environment but I changed the pythonpath accordingly so I don’t know if this is the problem.
      If somebody could kindly show their config.js with the module enabled this would be extremly helpful.
        sdetweil @Antagonist
        @Antagonist what does the developers window show?
          Antagonist
          Error log:
          SyntaxError: Unexpected token T in JSON at position 0
              at JSON.parse (<anonymous>)
              at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:358:21)
              at /home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:310:42
              at Array.forEach (<anonymous>)
              at PythonShell.recieveInternal (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:306:15)
              at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:290:21)
              at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:108:18)
              at Socket.emit (events.js:182:13)
              at addChunk (_stream_readable.js:279:12)
              at readableAddChunk (_stream_readable.js:260:13)
          { Error: ModuleNotFoundError: No module named 'cv2'
              at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:246:21)
              at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:129:32)
              at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:121:13)
              at ChildProcess.emit (events.js:182:13)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
              ----- Python Traceback -----
              File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 5, in <module>
                from stream import VideoStream
              File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/stream.py", line 2, in <module>
                from webcam import WebcamVideoStream
              File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/webcam.py", line 3, in <module>
                import cv2
            traceback:
             'Traceback (most recent call last):\n  File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 5, in <module>\n    from stream import VideoStream\n  File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/stream.py", line 2, in <module>\n    from webcam import WebcamVideoStream\n  File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/webcam.py", line 3, in <module>\n    import cv2\nModuleNotFoundError: No module named \'cv2\'\n',
            executable: 'python3',
            options: null,
            script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
            args:
             [ '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
               '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
               '--usePiCamera=1',
               '--method=dnn',
               '--detectionMethod=hog',
               '--interval=2000',
               '--output=0',
               '--extendDataset=False',
               '--dataset=modules/MMM-Face-Reco-DNN/dataset/' ],
            exitCode: 1 }
                import cv2
            traceback:
            options: null,
            args:
               '--usePiCamera=1',
               '--method=dnn',
               '--interval=2000',
               '--output=0',
            exitCode: 1 }
          TypeError: Cannot read property 'childProcess' of undefined
              at Class.destroy (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_helper.js:84:18)
              at Class.python_stop (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_helper.js:79:10)
              at Class.stop (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_helper.js:102:10)
              at App.stop (/home/pi/MagicMirror/js/app.js:247:16)
              at process.App.process.on (/home/pi/MagicMirror/js/app.js:261:8)
              at process.emit (events.js:182:13)
                import cv2
            traceback:
            options: null,
            args:
               '--usePiCamera=1',
               '--method=dnn',
               '--interval=2000',
               '--output=0',
            exitCode: 1 }
              at App.app.on (/home/pi/MagicMirror/js/electron.js:110:7)
              at App.emit (events.js:182:13)
              at Object.exports.execute (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item-roles.js:263:19)
              at MenuItem.click (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item.js:53:16)
              at Function.executeCommand (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:30:13)
                import cv2
            traceback:
            options: null,
            args:
               '--usePiCamera=1',
               '--method=dnn',
               '--interval=2000',
               '--output=0',
            exitCode: 1 }
                import cv2
            traceback:
            options: null,
            args:
               '--usePiCamera=1',
               '--method=dnn',
               '--interval=2000',
               '--output=0',
            exitCode: 1 }
                import cv2
            traceback:
            options: null,
            args:
               '--usePiCamera=1',
               '--method=dnn',
               '--interval=2000',
               '--output=0',
            exitCode: 1 }
          { Error: spawn home/pi/.virtualenvs/cv/bin/python3.7 ENOENT
              at Process.ChildProcess._handle.onexit (internal/child_process.js:229:19)
              at onErrorNT (internal/child_process.js:406:16)
              at process._tickCallback (internal/process/next_tick.js:63:19)
            errno: 'ENOENT',
            code: 'ENOENT',
            syscall: 'spawn home/pi/.virtualenvs/cv/bin/python3.7',
            path: 'home/pi/.virtualenvs/cv/bin/python3.7',
            spawnargs:
             [ 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
               '--usePiCamera=1',
               '--method=dnn',
               '--interval=2000',
               '--output=0',
               '--dataset=modules/MMM-Face-Reco-DNN/dataset/' ] }
          { Error: spawn home/pi/.virtualenvs/cv/bin/python3 ENOENT
            errno: 'ENOENT',
            code: 'ENOENT',
            syscall: 'spawn home/pi/.virtualenvs/cv/bin/python3',
            path: 'home/pi/.virtualenvs/cv/bin/python3',
            spawnargs:
               '--usePiCamera=1',
               '--method=dnn',
               '--interval=2000',
               '--output=0',
          Config.js:
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "de",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "Torbens Kalender",
          						symbol: "calendar-check",
                                  url: "https://calendar.google.com/calendar/ical/basic.ics",
                                  maximumEntries: "5",
                                  auth: {
                                      user: "user",
                                      pass: "mypass",
                                      method: "basic"
                      module: "compliments",
                      disabled: true,
                      position: "lower_third",
                          compliments: {
                              anytime: [
                                  "Hallo"
                              morning: [
                                  "Guten Morgen!",
                                  "Gut geschlafen?",
                              afternoon: [
                                  "Guten Tag",
                              evening: [
                                  "Guten Abend",
          			module: "currentweather",
          				locationID: "2895044",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "myappid"
          			module: "weatherforecast",
          			header: "Vorhersage",
          				appid: "myappid"
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "Spiegel",
          						url: "https://www.spiegel.de/schlagzeilen/tops/index.rss"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
                          broadcastNewsUpdates: true,
                          showDescription: true,
                          updateInterval: "20000"
          			module: 'MMM-Face-Reco-DNN',
          				// Logout 15 seconds after user was not detecte anymore, if they will be detected between this 15 Seconds, they delay will start again
          				logoutDelay: 15000,
          				// How many time the recognition starts, with a RasPi 3+ it would be good every 2 seconds
          				checkInterval: 2000,
          				// Module set used for strangers and if no user is detected
          				defaultClass: 'default',
          				// Set of modules which should be shown for every user
          				everyoneClass: 'everyone',
          				// XML to recognize with haarcascae
          				cascade: 'modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
          				// Pre encoded pickle with the faces
          				encodings: 'modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
          				// You wanna use pi camera or usb / builtin (1 = raspi camera, 0 = other camera)
          				usePiCamera: 1,
          				// Method of face detection (dnn = deep neural network, haar = haarcascade)
          				method: 'dnn',
          				// Which face detection model to use. "hog" is less accurate but faster on CPUs. "cnn" is a more accurate deep-learning model which is GPU/CUDA accelerated (if available).
          				detectionMethod: 'hog',
          				// How fast in ms should the modules hide and show (face effect)
          				animationSpeed: 0,
          				// Path to Python to run the face recognition (null / '' means default path)
          				pythonPath: '/home/pi/.virtualenvs/cv/bin/python3.7',
          				// Should shown welcome message over alert module from MagicMirror
          				welcomeMessage: true,
          				// Save some pictures from recognized people, if unknown we save it in folder "unknown"
          				// So you can extend your dataset and retrain it afterwards for better recognitions
          				extendDataset: false,
          				// if extenDataset is set, you need to set the full path of the dataset
          				dataset: 'modules/MMM-Face-Reco-DNN/dataset/'
          I don’t know but I’ve attached the error log and you can find my config.js above. Thank you and sorry for the long message.
            Blauenfeldt
            In between it all it says, that cv2 is not found. Your cv2 is probably not linked to your python 3.
              Antagonist @Blauenfeldt
              @Blauenfeldt Ahh that doesn’t sound very good. I’ve installed python in an virtual environment. Do you know a solution for this problem? Thanks a lot!
                @Antagonist did u follow the instructions for the module?
                https://github.com/nischi/MMM-Face-Reco-DNN#install-dependencies
                  Antagonist @sdetweil
                  @sdetweil Yes, I think I installed all dependencies accordingly and followed this instruction for opencv.
                    @Antagonist which python version… different solutions fror 2.7 or 3.x
                    see
                    https://stackoverflow.com/questions/19876079/cannot-find-module-cv2-when-using-opencv
                    ps… that is result of a google search on the error… I don’t know anything about this technology (python/cv2)
                      @sdetweil I have Python version 3.7.3.
                      And I have OpenCV 4.1.1 installed:
                      (cv) pi@raspberrypi:~ $ python
                      Python 3.7.3 (default, Apr  3 2019, 05:39:12)
                      [GCC 8.2.0] on linux
                      Type "help", "copyright", "credits" or "license" for more information.
                      >>> import cv2
                      >>> cv2.__version__
                      '4.1.1'
                      Thanks for your help!
                        @Antagonist but it doesn’t work in module, which means the path is not set properly
                          @sdetweil Ok but where can I adjust the path to link it properly with opencv? And thank you, you have been a great help so far!
                            @Antagonist I don’t know, read this
                            https://pypi.org/project/opencv-python/
                              @sdetweil unfortunately there is nothing which would help.
                              Has anybody else an idea?
                                Blauenfeldt
                                You need to go into your virtual environment, and link cv2 and python 3 together there (can’t remember which way it is), just like you did outside the environment.
                                  @Blauenfeldt I already did this:
                                    Antagonist
                                    Everything works. I’m just stupid as hell and didn’t add the classes to the other modules.
