    mirror not starting
    3 Posts 2 Posters 936 Views 2 Watching
      mrdenmark
      i’ve had the mirror running fine all day but the pi became unresponsive for some reason and wouldn’t respond to input(i was using chromium at the time and the mirror was minimised),i ended up pulling the power.
      upon starting the pi now,elctron starts and i get the MM splashscreen but then it goes no further.
      heres the log-
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
      2 info using npm@6.12.0
      3 info using node@v10.15.2
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
      6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
      7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.9.0~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
      11 silly lifecycle magicmirror@2.9.0~start: Returned: code: 1 signal: null
      12 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
      13 verbose stack Exit status 1
      13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack at EventEmitter.emit (events.js:189:13)
      13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack at ChildProcess.emit (events.js:189:13)
      13 verbose stack at maybeClose (internal/child_process.js:970:16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.9.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.75-v7+
      17 verbose argv “/usr/bin/node” “/usr/local/bin/npm” “start”
      18 verbose node v10.15.2
      19 verbose npm v6.12.0
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.9.0 start: sh run-start.sh
      22 error Exit status 1
      23 error Failed at the magicmirror@2.9.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      any suggestions?
        mrdenmark
        looking at the pm2 log i get this-
        magicmirror@2.9.0 start /home/pi/MagicMirror
        sh run-start.sh
        Starting MagicMirror: v2.9.0
        Loading config …
        Loading module helpers …
        Whoops! There was an uncaught exception…
        Launching application.
          sdetweil @mrdenmark
          @mrdenmark the pm2_error.log should show the exception
