    After installing google assistant and MagicMirror, the mirror screen comes up for 1 sec and then it crashes.
    2 Posts 2 Posters 749 Views 2 Watching
      AliensExist
      This is the error I get. Please help. Thanks
      magicmirror@2.9.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-AssistantMk2
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Starting module: newsfeed
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-AssistantMk2
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [AMK2] Temporal storage directory is clearing.
      [HOTWORD] No model to load
      [AMK2] assistant ready
      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.9.0 start: sh run-start.sh
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 start script.
      npm ERR! /home/pi/.npm/_logs/2019-11-15T21_50_03_527Z-debug.log
        sdetweil @AliensExist
        @AliensExist said in After installing google assistant and MagicMirror, the mirror screen comes up for 1 sec and then it crashes.:
        __atomic_store_8
        see this reply for the steps to recover… one of the libraries that module uses has a bug
        https://forum.magicmirror.builders/topic/11430/error-when-trying-to-run-mmm-assistantmk2/5
