    Issues with a special Google calendar
    19 Posts 3 Posters 5.1k Views 3 Watching
    • C Offline
      Clubjack @sdetweil
      @sdetweil ok. Thank You very much for your help. Great.
      • C Offline
        Clubjack @Clubjack
        @Clubjack
        I found the problem.
        I copyed the Module, to Show it on an other Page (mmm-pages). But that didnt work.
        With only one calendar it works great.
        Now i have some other questions.
        1. Is it possible to Change the timeformat from a date?
          From “16:00 Test” to “16 Test”.
        2. Is it possible to delete time from special entrys?
          From “14:00 work” to “work”?
        Edit: I was to fast. It only worked a few minutes.
        Now, i can do what i want, it dosnt show this calendar.
          sdetweil @Clubjack
          @Clubjack ext2 cannot by replicated onto different pages @Sean (author) said. he bypasses all the
          MM module presentation rules…
          • C Offline
            Clubjack @sdetweil
            @sdetweil now it works. there Was a Problem with an empty calendar Slot. 🙈
            Do You know, if my questions in the Post before, are makeable?
              sdetweil @Clubjack
              @Clubjack sure… u can select the three dots to the right on any post to mark it
              • C Offline
                Clubjack @sdetweil
                @sdetweil not markable… Makeable😉
                  sdetweil @Clubjack
                  @Clubjack sorry, mind sees what it wants to see!
                  https://github.com/eouia/MMM-CalendarExt2/blob/master/doc/Configuration/View.md
                  dateFormat	Object	{...}	{...}	See Event Time.
                  timeFormat	Object	{...}	{...}	See Event Time.
                  dateTimeFormat	Object	{...}	{...}	See Event Time.
                  relativeFormat	Object	{...}	{...}	See Event Time.
                  • C Offline
                    Clubjack @sdetweil
                    Oh, right, I saw that once. But forget it again. Thank You
                    • BKeyportB Offline
                      BKeyport Module Developer
                      by the way, if you wanna dump the empty slots:
                      1. in config.js under views add
                      className: "remove_empty_slot",
                      1. add the following css to custom.css
                      /* CalExt2 - Hide empty days on agenda */
                      .CX2 .remove_empty_slot .eventCount_0 {
                              display:none;
