    "Out of memory" issues - where do I begin?
    65 Posts 2 Posters 31.6k Views 2 Watching
      sdetweil @ember1205
      @ember1205 the upgrade doesn’t know about your local change to use run-start… but all u had to do was restore that one line in package.json
      it now seems that it is refusing to run the upgrade script
      show me the ~/MagicMirror/installers/upgrade.log
      • E Offline
        ember1205 @sdetweil
        @sdetweil This is all that it spits out on a test run (and MM no longer shows that it is out of date but it is):
        Upgrade started - Mon Dec 28 09:07:08 EST 2020
        system is Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
        doing test run = true, NO updates will be applied!
        saving custom.css
        Unable to determine upstream git repository
        restoring custom.css
        removing git alias
        Upgrade ended - Mon Dec 28 09:07:09 EST 2020
        I tried connecting to a couple of web sites via CURL and it throws errors about loading certificates and these sites should work fine. So, the combo of everything is why I’m suspecting that there is a certificate issue due to an older OS on the Pi. I’m doing an upgrade on it now…
          sdetweil @ember1205
          @ember1205 when u made your backup, how did u do it? you may not have backed up the git repo
          from the MagicMirror folder
          do a git status
          and ls .git (notice the leading dot)
          • E Offline
            ember1205 @sdetweil
            @sdetweil I honestly don’t recall if I renamed the original folder MM-backup/ and then did rsync back to MagicMirror/ or just did rsync to MM-backup/. My rsync would have been with flags ‘-vaPHSx’, so either way it should have gotten everything.
            I’ll check for the .git directory…
            • E Offline
              ember1205
              I can’t seem to get the system to tell me that it’s out of date again (even though I know it is). That’s ok for now, though… New problem…
              Chromium is crashing, and I have a guess as to what might be going on. I have been searching and can not find anything related to a log file for Chromium, though, and I would need to be able to see that to understand if my suspicion is correct. Am I just completely missing it?
              • 6
              • 7
              • 7 / 7
