    config.js file Calendar part, don't show the 4th ICS and mess up the date format
    5 Posts 2 Posters 1.3k Views 2 Watching
      siraero
      Hi
      I have two issues with the new 2.10 of MM.
      have added a 4th. ICS (https://calendar.google.com/calendar/ical/da.danish%23holiday%40group.v.calendar.google.com/public/basic.ics) and I can’t get it to show the dates in the “calendars” the 3 other ICS is working fine.
      Image link https://drive.google.com/open?id=1SywDaeJ4MWxtpUFDbwZ75G9gEW9CUHjT
      The last link is the link in the ( ), and is not showed…
      calendars: [ { symbol: "calendar", url: "1. LINK TO WORKING GOOGLE ICS" }, { symbol: "birthday-cake", url: "2. LINK TO WORKING GOOGLE ICS" }, { symbol: "calendar", url: "3. LINK TO WORKING GOOGLE ICS" }, { symbol: "calendar", url: "https://calendar.google.com/calendar/ical/da.danish%23holiday%40group.v.calendar.google.com/public/basic.ics" } ]
      Im using fullDayEventDateFormat: “DD MMM” but appears as “Do MMM” (21. jan - maybe) for every second lines and “MMM Do” (Jan 25. - maybe) for the others in between.
      Image link https://drive.google.com/open?id=1q1u-o7qkh6xNX8R88LOieJCmcWbKIyoy
      config: { fullDayEventDateFormat: "DD MMM", timeFormat: "absolute", urgency: 7, calendars: [ .......... ] }
      Can someone help with...
      Why the 4th ICS link is not showed
      Why i get the two datetypes Do MMM and MMM Do, when I im my config.js file have DD MMM
      Have tried this, but with no luck :-)
      https://forum.magicmirror.builders/topic/9894/default-module-calendar-not-updating
      Can someone guide/help me ?
        sdetweil
        I put your config into a newly installed MM installation (2.10)
        			header: "US Holidays",
        						symbol: "calendar-check",
        						// url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
        and I see 10 calendar entries, the 1st is Feb 14, the last is May 5.
          sdetweil @siraero
          @siraero if u move that cal entry to the top, does this one show and the new last one not show?
            siraero @sdetweil
            @sdetweil said in config.js file Calendar part, don't show the 4th ICS and mess up the date format:
            Hi
            Have just moved the cal entry to the top, and it’s the same issue - it will not show the dates and it still show the other dates as Do MMM and MMM Do, and my FullDayEventDate Format is DD MMM…
            Then I hardreset is (Power off and on again) and now its sat “No Avalible events”…
            Unfortunately, you are right… that a clean installation is what it takes.
            Think it’s from 1.9 I started with and have so constantly updated my screen.
            So that may be why it behaves strangely.
            Thank you anyway :-)
              sdetweil @siraero
              @siraero its probably the downlevel ical library in the calendar/vendor folderr
