    MM electron command not found after update
    3 Posts 2 Posters 973 Views 2 Watching
    • H
      HarrisonHeroux
      My MM will not start up anymore after performing the update. I updated with the git pull command in the MM folder. Then I got this error:
      0|mm       | A JavaScript error occurred in the main process
      0|mm       | Uncaught Exception:
      0|mm       | Error: Cannot find module 'module-alias/register'
      0|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      0|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
      0|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
      0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:1)
      0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:283:3)
      0|mm       |     at Module._compile (internal/modules/cjs/loader.js:711:30)
      0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
      0|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)
      Searching the forum it seemed like this had to do with forgetting about including the npm install command. So that is what I did next. Both with the git pull and the second attempt with npm install I forgot to stop MM with pm2. Then I got this message about electron not beeing found:
      0|mm       | npm ERR! A complete log of this run can be found in:
      0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-05T20_04_07_508Z-debug.log
      0|mm       | ./run-start.sh: line 66: electron: command not found
      0|mm       | npm ERR! code ELIFECYCLE
      0|mm       | npm ERR! syscall spawn
      0|mm       | npm ERR! file sh
      0|mm       | npm ERR! errno ENOENT
      0|mm       | npm ERR! magicmirror@2.10.0 start: `./run-start.sh`
      0|mm       | npm ERR! spawn ENOENT
      0|mm       | npm ERR!
      0|mm       | npm ERR! Failed at the magicmirror@2.10.0 start script.
      0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|mm       |
      0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-05T20_04_09_849Z-debug.log
      Then I tried running the installer supplied by Sam, as sugested in several post. Running the command “bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply” didn’t throw any errors but after rebooting MM was not working. pm2 logs mm gives the same electron error as before and here is the log form the upgradescript:
      Upgrade started - Sun Jan  5 21:07:58 CET 2020
      system is Linux magicmirror 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      doing test run = true
      saving custom.css
      remote name = origin
      upgrading from version 2.10.0 to 2.10.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is up to date with 'origin/master'.
      Changes not staged for commit:
        (use "git add <file>..." to update what will be committed)
        (use "git checkout -- <file>..." to discard changes in working directory)
      	modified:   package-lock.json
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
      	css/save_custom.css
      	nohup.out
      no changes added to commit (use "git add" and/or "git commit -a")
      there are 1 local files that are different than the master repo
         package-lock.json
      save/restore files selection = Y
      test merge result rc='' , if empty, no conflicts
      skipping merge, only test run
      processing dependency changes for active modules with package.json files
      processing for module MMM-MyDutchWeather please wait
      skipped processing for MMM-MyDutchWeather, doing test run
      processing complete for module MMM-MyDutchWeather
      processing for module MMM-network-signal please wait
      skipped processing for MMM-network-signal, doing test run
      processing complete for module MMM-network-signal
      restoring custom.css
      test run, restoring files stashed
      Upgrade ended - Sun Jan  5 21:08:16 CET 2020
      Upgrade started - Sun Jan  5 21:09:18 CET 2020
      user requested to apply changes
      doing test run = false
      saving custom.css
      local version 2.10.0 already same as master 2.10.0
      Upgrade ended - Sun Jan  5 21:09:18 CET 2020
      So it seems Electron is up to date, but somehow the command isn’t recognized. What can I do to solve the error?
      • H
        HarrisonHeroux @sdetweil
        Just booted the MM and it is working again. Do no know why it now runs ok and yesterday not (didn’t do anything new). So I guess this topic is solved.
          sdetweil @HarrisonHeroux
          @HarrisonHeroux do an
          npm install
          In the MagicMirror folder
          • H
