    Touch foil, maybe a solution ?
    14 Posts 6 Posters 9.0k Views 8 Watching
    • W Offline
      wibimaster
      So, Mirrorworld Ultra Silver (GX010) is really good ; better reflection than ChromeSpy because more “silver” and less “brown”, and a little better transmitance than Mirastar.
      It’s a really little improvements, and it has a cost + a weight, only in 6mm, need a good frame (wood, …)
      So, best choice if no touch foil and no need of great colors behind, and with a good hard frame (a lot heavier)
      • T Offline
        TattyJJ
        Hi @wibimaster I was looking at doing a very similar project to you.
        How did you get on with the touch foil and mirror samples?
          Barryb0ng
          Hi
          I also wounder if someone have succeded with touch foil on a magicmirror and then how
            andrei10
            Hi, I saw your post and I m exactly in the same position.
            I already bought a 24” touch foil. I tested with a transparent glass and it s working 100%. But when I put above the two way mirror glass…the touch foil doesn t work.
            Can you please tell me what kind of glass do I have to use? I need to buil an oval magic mirror.
            Andrei
            firi1087@gmail.com
