    Cant update from 2.9.0 > 2.10.0 using update script
    3 Posts 2 Posters 893 Views 2 Watching
    • H
      HarryBerry
      today I was looking at my mirror and saw I had to update, so I tried to use MichMich’s update script
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)" apply
      I got this Error
      the log will be /home/pi/MagicMirror/installers/upgrade.log
      No LSB modules are available.
      doing test run = false
      update log will be in /home/pi/MagicMirror/installers/upgrade.log
      saving custom.css
      upgrading from version 2.9.0 to 2.10.0
      fetching latest revisions
      there were merge errors
      error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
      you should examine and resolve them
      using the command git log --oneline --decorate
      500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
      restoring custom.css
      Then I did
      sudo rm -f ~/MagicMirror/installers/dumpactivemodules.js
      Tried again and got the same error above
      then I tried @sdetweil update script
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      and got his error
      saving custom.css
      Unable to determine upstream git repository
      I’ve tried troubleshooting for a bit but can’t seem to fix it
      my upgrade.log shows this
      Upgrade started - Mon Jan  6 06:38:49 GMT 2020
      system is Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      user requested to apply changes
      saving custom.css
      not english or locale not set, set git alias
      alias git='LANG=en_US.UTF-8 git'
      removing git alias
      Upgrade ended - Mon Jan  6 06:38:50 GMT 2020
      I hope you guys can help!
        sdetweil @HarryBerry
        @HarryBerry try my updated script again
        • H
          HarryBerry
          It works whatever you did thanks!
