    Error [ERR_STREAM_DESTROYED]
    7 Posts 2 Posters 2.3k Views 2 Watching
      jorgnyg
      After some MM up-time on the rpi zero I get the following error.
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm       |     at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10)
      0|mm       |     at process.emit (events.js:198:13)
      0|mm       |     at process._fatalException (internal/bootstrap/node.js:497:27)
      0|mm       | events.js:174
      0|mm       |       throw er; // Unhandled 'error' event
      0|mm       |       ^
      0|mm       |
      0|mm       | Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      0|mm       |     at doWrite (_stream_writable.js:411:19)
      0|mm       |     at writeOrBuffer (_stream_writable.js:399:5)
      0|mm       |     at Socket.Writable.write (_stream_writable.js:299:11)
      0|mm       |     at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
      Seems like it’s loosing internet connections or something, since modules fails to fetch new data after the error.
      Can’t find additional error code other than the added output, so how can I debug this? Anyone facing the same problem?
      S 3 Replies Last reply Reply Quote 0
        sdetweil @jorgnyg
        @jorgnyg once it fails, that code is dead…
        this is probably a timing error, because the 0 is slower than the rest
        will look at it…
          sdetweil @jorgnyg
          @jorgnyg can u do
          pm2 logs --lines=100
          (note two dashes)
            jorgnyg @sdetweil
            @sdetweil Yes I agree with the timing error fault. we just have to figure out where.
            Log output here:
            TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
            /home/pi/.pm2/pm2.log last 100 lines:
            PM2        | 2020-01-10T22:33:44: PM2 log: Stopping app:mm id:0
            PM2        | 2020-01-10T22:33:45: PM2 log: pid=3185 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-10T22:33:46: PM2 log: pid=3185 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-10T22:33:47: PM2 log: pid=3185 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-10T22:33:47: PM2 log: Process with pid 3185 still alive after 1600ms, sending it SIGKILL now...
            PM2        | 2020-01-10T22:33:49: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
            PM2        | 2020-01-10T22:33:49: PM2 log: pid=3185 msg=process killed
            PM2        | 2020-01-10T22:35:20: PM2 log: App [mm:0] starting in -fork mode-
            PM2        | 2020-01-10T22:35:20: PM2 log: App [mm:0] online
            PM2        | 2020-01-11T00:06:25: PM2 log: Stopping app:mm id:0
            PM2        | 2020-01-11T00:06:27: PM2 log: pid=4479 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T00:06:28: PM2 log: pid=4479 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T00:06:29: PM2 log: pid=4479 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T00:06:29: PM2 log: Process with pid 4479 still alive after 1600ms, sending it SIGKILL now...
            PM2        | 2020-01-11T00:06:31: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
            PM2        | 2020-01-11T00:06:31: PM2 log: pid=4479 msg=process killed
            PM2        | 2020-01-11T00:07:12: PM2 log: App [mm:0] starting in -fork mode-
            PM2        | 2020-01-11T00:07:12: PM2 log: App [mm:0] online
            PM2        | 2020-01-11T00:11:39: PM2 log: Stopping app:mm id:0
            PM2        | 2020-01-11T00:11:41: PM2 log: pid=11984 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T00:11:42: PM2 log: pid=11984 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T00:11:42: PM2 log: Process with pid 11984 still alive after 1600ms, sending it SIGKILL now...
            PM2        | 2020-01-11T00:11:45: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
            PM2        | 2020-01-11T00:11:45: PM2 log: pid=11984 msg=process killed
            PM2        | 2020-01-11T00:22:43: PM2 log: App [mm:0] starting in -fork mode-
            PM2        | 2020-01-11T00:22:43: PM2 log: App [mm:0] online
            PM2        | 2020-01-11T09:32:55: PM2 log: ===============================================================================
            PM2        | 2020-01-11T09:32:55: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
            PM2        | 2020-01-11T09:32:55: PM2 log: Time                 : Sat Jan 11 2020 09:32:55 GMT+0100 (Central European Standard Time)
            PM2        | 2020-01-11T09:32:55: PM2 log: PM2 version          : 4.2.1
            PM2        | 2020-01-11T09:32:55: PM2 log: Node.js version      : 10.18.1
            PM2        | 2020-01-11T09:32:55: PM2 log: Current arch         : arm
            PM2        | 2020-01-11T09:32:55: PM2 log: PM2 home             : /home/pi/.pm2
            PM2        | 2020-01-11T09:32:55: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
            PM2        | 2020-01-11T09:32:55: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
            PM2        | 2020-01-11T09:32:55: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
            PM2        | 2020-01-11T09:32:55: PM2 log: Application log path : /home/pi/.pm2/logs
            PM2        | 2020-01-11T09:32:55: PM2 log: Worker Interval      : 30000
            PM2        | 2020-01-11T09:32:55: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
            PM2        | 2020-01-11T09:32:55: PM2 log: Concurrent actions   : 2
            PM2        | 2020-01-11T09:32:55: PM2 log: SIGTERM timeout      : 1600
            PM2        | 2020-01-11T09:32:57: PM2 log: App [mm:0] starting in -fork mode-
            PM2        | 2020-01-11T09:32:57: PM2 log: App [mm:0] online
            PM2        | 2020-01-11T09:41:08: PM2 log: Stopping app:mm id:0
            PM2        | 2020-01-11T09:41:10: PM2 log: pid=827 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T09:41:11: PM2 log: pid=827 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T09:41:12: PM2 log: pid=827 msg=failed to kill - retrying in 100ms
            PM2        | 2020-01-11T09:41:12: PM2 log: Process with pid 827 still alive after 1600ms, sending it SIGKILL now...
            PM2        | 2020-01-11T09:41:14: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
            PM2        | 2020-01-11T09:41:14: PM2 log: pid=827 msg=process killed
            /home/pi/.pm2/logs/mm-out.log last 100 lines:
            0|mm       | [22:35:42.053] [LOG] Starting node helper for: MMM-Trello
            0|mm       | [22:35:42.064] [LOG] Sockets connected & modules started ...
            0|mm       | [22:35:42.072] [LOG]
            0|mm       | Ready to go! Please point your browser to: http://localhost:8080
            0|mm       | Starting chromium browser now, have patience, it takes a minute
            0|mm       |
            0|mm       | > magicmirror@2.10.0 start /home/pi/MagicMirror
            0|mm       | > ./run-start.sh
            0|mm       |
            0|mm       | [00:07:26.988] [LOG] Starting MagicMirror: v2.10.0
            0|mm       | [00:07:27.103] [LOG] Loading config ...
            0|mm       | [00:07:27.142] [LOG] Loading module helpers ...
            0|mm       | [00:07:27.161] [LOG] No helper found for module: alert.
            0|mm       | [00:07:27.174] [LOG] No helper found for module: clock.
            0|mm       | [00:07:31.751] [LOG] Initializing new module helper ...
            0|mm       | [00:07:31.760] [LOG] Module helper loaded: calendar
            0|mm       | [00:07:31.776] [LOG] No helper found for module: compliments.
            0|mm       | [00:07:31.792] [LOG] No helper found for module: currentweather.
            0|mm       | [00:07:31.801] [LOG] No helper found for module: weatherforecast.
            0|mm       | [00:07:32.012] [LOG] Initializing new module helper ...
            0|mm       | [00:07:32.022] [LOG] Module helper loaded: MMM-Spotify
            0|mm       | [00:07:35.649] [LOG] Initializing new module helper ...
            0|mm       | [00:07:35.658] [LOG] Module helper loaded: MMM-Trello
            0|mm       | [00:07:35.668] [LOG] All module helpers loaded.
            0|mm       | [00:07:35.675] [LOG] Starting server on port 8080 ...
            0|mm       | [00:07:35.808] [LOG] Server started ...
            0|mm       | [00:07:35.822] [LOG] Connecting socket for: calendar
            0|mm       | [00:07:35.832] [LOG] Starting node helper for: calendar
            0|mm       | [00:07:35.844] [LOG] Connecting socket for: MMM-Spotify
            0|mm       | [00:07:35.870] [LOG] [SPOTIFY_AUTH] Token is expired. It will be refreshed
            0|mm       | [00:07:35.881] [LOG] [SPOTIFY_AUTH] Token refreshing...
            0|mm       | [00:07:36.004] [LOG] Connecting socket for: MMM-Trello
            0|mm       | [00:07:36.018] [LOG] Starting node helper for: MMM-Trello
            0|mm       | [00:07:36.022] [LOG] Sockets connected & modules started ...
            0|mm       | [00:07:36.031] [LOG]
            0|mm       |
            0|mm       |
            0|mm       | [00:22:57.441] [LOG] Starting MagicMirror: v2.10.0
            0|mm       | [00:22:57.555] [LOG] Loading config ...
            0|mm       | [00:22:57.593] [LOG] Loading module helpers ...
            0|mm       | [00:22:57.611] [LOG] No helper found for module: alert.
            0|mm       | [00:22:57.624] [LOG] No helper found for module: clock.
            0|mm       | [00:23:00.940] [LOG] Initializing new module helper ...
            0|mm       | [00:23:00.950] [LOG] Module helper loaded: calendar
            0|mm       | [00:23:00.961] [LOG] No helper found for module: compliments.
            0|mm       | [00:23:00.972] [LOG] No helper found for module: currentweather.
            0|mm       | [00:23:00.983] [LOG] No helper found for module: weatherforecast.
            0|mm       | [00:23:01.192] [LOG] Initializing new module helper ...
            0|mm       | [00:23:01.214] [LOG] Module helper loaded: MMM-Spotify
            0|mm       | [00:23:04.094] [LOG] Initializing new module helper ...
            0|mm       | [00:23:04.102] [LOG] Module helper loaded: MMM-Trello
            0|mm       | [00:23:04.113] [LOG] All module helpers loaded.
            0|mm       | [00:23:04.120] [LOG] Starting server on port 8080 ...
            0|mm       | [00:23:04.248] [LOG] Server started ...
            0|mm       | [00:23:04.259] [LOG] Connecting socket for: calendar
            0|mm       | [00:23:04.271] [LOG] Starting node helper for: calendar
            0|mm       | [00:23:04.283] [LOG] Connecting socket for: MMM-Spotify
            0|mm       | [00:23:04.305] [LOG] [SPOTIFY_AUTH] Token is fresh.
            0|mm       | [00:23:04.314] [LOG] Connecting socket for: MMM-Trello
            0|mm       | [00:23:04.324] [LOG] Starting node helper for: MMM-Trello
            0|mm       | [00:23:04.336] [LOG] Sockets connected & modules started ...
            0|mm       | [00:23:04.341] [LOG]
            0|mm       |
            0|mm       |
            0|mm       | [09:33:18.789] [LOG] Starting MagicMirror: v2.10.0
            0|mm       | [09:33:18.865] [LOG] Loading config ...
            0|mm       | [09:33:18.904] [LOG] Loading module helpers ...
            0|mm       | [09:33:18.924] [LOG] No helper found for module: alert.
            0|mm       | [09:33:18.936] [LOG] No helper found for module: clock.
            0|mm       | [09:33:22.347] [LOG] Initializing new module helper ...
            0|mm       | [09:33:22.358] [LOG] Module helper loaded: calendar
            0|mm       | [09:33:22.371] [LOG] No helper found for module: compliments.
            0|mm       | [09:33:22.381] [LOG] No helper found for module: currentweather.
            0|mm       | [09:33:22.392] [LOG] No helper found for module: weatherforecast.
            0|mm       | [09:33:22.559] [LOG] Initializing new module helper ...
            0|mm       | [09:33:22.568] [LOG] Module helper loaded: MMM-Spotify
            0|mm       | [09:33:25.558] [LOG] Initializing new module helper ...
            0|mm       | [09:33:25.567] [LOG] Module helper loaded: MMM-Trello
            0|mm       | [09:33:25.578] [LOG] All module helpers loaded.
            0|mm       | [09:33:25.585] [LOG] Starting server on port 8080 ...
            0|mm       | [09:33:25.742] [LOG] Server started ...
            0|mm       | [09:33:25.755] [LOG] Connecting socket for: calendar
            0|mm       | [09:33:25.772] [LOG] Starting node helper for: calendar
            0|mm       | [09:33:25.780] [LOG] Connecting socket for: MMM-Spotify
            0|mm       | [09:33:25.813] [LOG] [SPOTIFY_AUTH] Token is expired. It will be refreshed
            0|mm       | [09:33:25.820] [LOG] [SPOTIFY_AUTH] Token refreshing...
            0|mm       | [09:33:26.055] [LOG] Connecting socket for: MMM-Trello
            0|mm       | [09:33:26.066] [LOG] Starting node helper for: MMM-Trello
            0|mm       | [09:33:26.077] [LOG] Sockets connected & modules started ...
            0|mm       | [09:33:26.085] [LOG]
            /home/pi/.pm2/logs/mm-error.log last 100 lines:
            0|mm       | ./run-start.sh: line 67: 24163 Aborted                 (core dumped) chromium-browser -noerrdialogs -kiosk -start_maximized --disable-infobars --app=http://localhost:$port --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2> /dev/null
            0|mm       | npm ERR! code ELIFECYCLE
            0|mm       | npm ERR! errno 134
            0|mm       | npm ERR! magicmirror@2.10.0 start: `./run-start.sh`
            0|mm       | npm ERR! Exit status 134
            0|mm       | npm ERR!
            0|mm       | npm ERR! Failed at the magicmirror@2.10.0 start script.
            0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            0|mm       |
            0|mm       | npm ERR! A complete log of this run can be found in:
            0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-10T19_57_51_885Z-debug.log
            0|mm       |       ^
            0|mm       |
            0|mm       | ./run-start.sh: line 67:  4392 Aborted                 (core dumped) chromium-browser -noerrdialogs -kiosk -start_maximized --disable-infobars --app=http://localhost:$port --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2> /dev/null
            0|mm       | npm ERR!
            0|mm       |
            0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-10T20_56_57_189Z-debug.log
            0|mm       |       ^
            0|mm       |
            0|mm       |       ^
            0|mm       |
            0|mm       |       ^
            0|mm       |
            0|mm       |       ^
            0|mm       |
            0|mm       |       ^
            0|mm       |
              jorgnyg
              Some additional logs from /home/pi/.npm/_logs
              1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
              2 info using npm@6.13.4
              3 info using node@v10.18.1
              5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
              6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
              7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
              8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
              10 silly lifecycle magicmirror@2.10.0~start: Args: [ '-c', './run-start.sh' ]
              11 silly lifecycle magicmirror@2.10.0~start: Returned: code: 134  signal: null
              12 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
              13 verbose stack Error: magicmirror@2.10.0 start: `./run-start.sh`
              13 verbose stack Exit status 134
              13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
              13 verbose stack     at EventEmitter.emit (events.js:198:13)
              13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
              13 verbose stack     at ChildProcess.emit (events.js:198:13)
              13 verbose stack     at maybeClose (internal/child_process.js:982:16)
              13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
              14 verbose pkgid magicmirror@2.10.0
              15 verbose cwd /home/pi/MagicMirror
              16 verbose Linux 4.19.75+
              17 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
              18 verbose node v10.18.1
              19 verbose npm  v6.13.4
              20 error code ELIFECYCLE
              21 error errno 134
              22 error magicmirror@2.10.0 start: `./run-start.sh`
              22 error Exit status 134
              23 error Failed at the magicmirror@2.10.0 start script.
              23 error This is probably not a problem with npm. There is likely additional logging output above.
              24 verbose exit [ 134, true ]
                sdetweil @jorgnyg
                @jorgnyg said in Error [ERR_STREAM_DESTROYED]:
                Exit status 134
                when this happens can u use a terminal window and do
                ps -ef | grep -v color | grep chromium
                I think the chromium browser is hung
                and we keep trying to restart and it fails
                  sdetweil @jorgnyg
                  @jorgnyg this is a bug in the run-start.sh script
                  get a new one here
                  cd !/MagicMirror
                  curl -sL  https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
