    MMM-CalendarEXT2 - Event color changes
    4 Posts 2 Posters 2.2k Views 2 Watching
      suspect24
      I have the module working perfectly but the only thing I want to do is slightly change the color of the events sometimes the grey is hard to read. I tried figuring out the custom css but I have no clue what I am doing or what I am looking for can anyone help?
      I have it setup with a weekly view with 5 slot in fullscreen_below and a daily view with 3 slot in the top_right.
      C 1 Reply Last reply
      • C
        cskenney @suspect24
        @suspect24 There are a couple ways to make the change.
        Are you trying to change all the entries from a specific calendar? If you are you want to assign a className to the calendar and then use that className in the custom.css file.
        Here is an example:
        						name: "MHS Softball",
        						url: "https://calendar.google.com/calendar/ical/example.ics",
        						className: "cal_mhs_softball",
        Then in the custom.css file you would include the entry to change the background color of the specified className. Like this:
        .CX2 .event.cal_mhs_softball {
        	background-color:rgba(128,0,0,1);
        I have also successfully used the transform function to search the Title of an event for a specific keyword. Once found I assign an event.className to that event. Then in the custom.css file I can change the background color for that specific event className.
        Reply Quote 1
          suspect24 @cskenney
          @cskenney so how do I use the transform function to find the item I want to change? When I look through the css file there’s a lot in there, none of which makes any logical sense to me. Haha
          • C
            cskenney @suspect24
            @suspect24 Here is how I implemented the transform function.
            Background: my daughter plays on a softball team that contains the word “Panic”. I want to change the background color to match the team color and I want to include a softball icon for the event.
            I add the following code to the defaultSet section in MMM-CalendarExt2. This means every time the word “Panic” is found in an event title that the commands following are executed.
            Note: I have an If…else If structure here so I can actually transform a number of items.
            defaultSet: {
            						calendar: {
            							maxItems: 500,
            							scanInterval: 1000*60*1,
            							beforeDays: 5,
            							afterDays: 60,
            							maxIterations: 100,
            						view: {
            							timeFormat: "h:mm A",
            							transform: function(event) {
            								if (event.title.search("Panic") > -1) {
            								event.icon = "noto-softball";
            								event.className = "view_panic";
            								} else if (event.title.search("Arin") > -1) {
            								} else if (event.title.search("Violin") > -1) {
            								event.icon = "emojione-monotone:violin";
            								return event;
            						scene: {}
            Now that I have assigned a className object to the events that contain the word “Panic” I can use that object in the custom. css file.
            .CX2 .event.view_panic {
            	background-color:rgba(139,0,139,1);
            There may be other ways to do this but this one worked out well for me.
