    MMM-CalendarEXT2 - Change Icon Size
    3 Posts 2 Posters 1.0k Views 2 Watching
      Apartment_Moose
      Having some trouble getting the right code in my custom.css for changing icon sizes for this particular module only. any help would be great as i would like to increase the icon size by roughly +15% or so.
      • ? Offline
        A Former User @Apartment_Moose
        @Apartment_Moose
        It depends on font-size of event basically.
        See this;
        https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling#some-default-sizes
        .CX2 { /* default values which are used frequently or dependently */
          --row-min-width: 100px;
          --row-max-width: 1000px;
          --column-min-width: 300px;
          --column-max-width: 400px;
          --font-size: 16px;
        Adjust --font-size as your wish.
        Of course, you can forcibly set eventIcon on CSS also.
        By default it is defined like this. (MMM-CalendarExt2.css)
        .CX2 .period .eventIcon {
          min-width: calc(var(--font-size) * 2);
          min-height: calc(var(--font-size) * 2);
          margin-right:5px;
          float:left;
        .CX2 .weekSlot .eventIcon {
          min-width: var(--font-size);
          min-height: var(--font-size);
          margin-right:3px;
          display:block;
          padding-bottom:3px;
        So you can redefine/override them in your css/custom.css. But for harmony with text, I recommend you to use --font-size globally.
          Apartment_Moose
          @Sean
          thanks for the help, i didnt realize icon size was set by --font-size as well, i will take your advice and run with adjusting the font globally for the module.
          thanks alot!
