    update magic mirror
    19 Posts 3 Posters 6.8k Views 3 Watching
    • R
      Raxos
      hi !
      Today i have a problem with the update. The screen show the message “an update is available, need 4 commits”, but when i do the command on the readme, my terminal say “no module found needing npm refresh” and many error about save_custom.css.
      More, i would like know if they are something to do to make automatic installation update .
      best regards
        sdetweil @mastadook
        @mastadook ok, you are starting in the wrong place with the wrong script…
        in folder
             /home/pi
        start this
            /home/pi/MagicMirror
        use my pm2 fixup script…
        do this
        pm2 delete 0
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
          sdetweil @Raxos
          @Raxos I think you are running the upgrade script? if so, can u show me the
          ~/MagicMirror/installers/upgrade.log
          that message means there are no active installed modules (in the modules folder) which contain a package.json file
          • R
            Raxos
            i use the command bash -c “$(curl -sl https://raw.gitusercontent/miuchmich/magicmirror/master/installers/upgrade-script.sh)”
            the log : https://drive.google.com/open?id=1t1eFgTcRHwEFOalFnfDFjbiW5g80V6VT
              sdetweil @Raxos
              @Raxos that link is not valid. The scripts have been moved to an external site for a few weeks now. (That exact script has a fatal bug)
              See the scripts here
              Also, the Google drive link is not shared.
              • R
                Raxos
                okay, so if i understand, i nedd to do bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                the log: https://drive.google.com/file/d/1t1eFgTcRHwEFOalFnfDFjbiW5g80V6VT/view?usp=sharing
                  sdetweil @Raxos
                  @Raxos ok, can you execute these commands and tell me the results
                  LC_ALL=C git status
                  locale
                  • M
                    mastadook
                    after Update I have this Problem: Any Idea?
                    0|MagicMirror | > magicmirror@2.10.1 start /home/pi/MagicMirror
                    0|MagicMirror | > ./run-start.sh
                    0|MagicMirror | ./run-start.sh: Zeile 66: electron: Kommando nicht gefunden.
                    0|MagicMirror | npm
                    0|MagicMirror | ERR! code ELIFECYCLE
                    0|MagicMirror | npm
                    0|MagicMirror | ERR! syscall spawn
                    0|MagicMirror | npm ERR! file
                    0|MagicMirror | sh
                    0|MagicMirror | npm ERR! errno ENOENT
                    0|MagicMirror | npm
                    0|MagicMirror | ERR! magicmirror@2.10.1 start: ./run-start.sh
                    0|MagicMirror | npm ERR! spawn ENOENT
                    0|MagicMirror | npm
                    0|MagicMirror | ERR! Failed at the magicmirror@2.10.1 start script.
                    0|MagicMirror | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                    0|MagicMirror | npm ERR! A complete log of this run can be found in:
                    0|MagicMirror | npm ERR! /home/pi/.npm/_logs/2020-01-31T15_08_06_616Z-debug.log
                    What can I do?
                    Regards
                    Clemens
                      sdetweil
                      @mastadook can u tell us more?
                      What version did u upgrade from?
                      Show output of
                      uname
                      npm -v
                      node -v
                      • M
                        mastadook
                        Hi Sam,
                        here are the requested Infos:
                        pi@magicmirror:~ $ uname
                        Linux
                        pi@magicmirror:~ $ npm -v
                        6.13.4
                        pi@magicmirror:~ $ node -v
                        v10.18.1
                        Errormessage after npm install
                        0|MagicMirror | path: ‘package.json’ }
                        0|MagicMirror | [15:31:05.578] [ERROR]
                        0|MagicMirror | { Error: ENOENT: no such file or directory, open ‘package.json’
                        0|MagicMirror | at Object.openSync (fs.js:443:3)
                        0|MagicMirror | at Object.readFileSync (fs.js:343:35)
                        0|MagicMirror | at Object. (/home/pi/MagicMirror/js/app.js:21:32)
                        0|MagicMirror | at Module._compile (internal/modules/cjs/loader.js:778:30)
                        0|MagicMirror | at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                        0|MagicMirror | at Module.load (internal/modules/cjs/loader.js:653:32)
                        0|MagicMirror | at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        0|MagicMirror | at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                        0|MagicMirror | at Module.require (internal/modules/cjs/loader.js:692:17)
                        0|MagicMirror | at Module.Hook._require.Module.require (/usr/lib/node_modules/pm2/node_modules/require-in-the-middle/index.js:70:39)
                        0|MagicMirror | errno: -2,
                        0|MagicMirror | syscall: ‘open’,
                        0|MagicMirror | code: ‘ENOENT’,
                        It works for some hours, after restart the Errormessage comes back.
                          sdetweil @mastadook
                          @mastadook said in update magic mirror:
                          can u tell me what modules u have installed? (folder names in MagicMirror/modules, excluding default)
                          there is one module I know of that uses pm2 to launch another component under the covers
                          how did u upgrade to 2.10.1?
                          • M
                            mastadook
                            Hi
                            pi@magicmirror:~/MagicMirror/modules $ ls
                            default MMM-DailyBibleVerse MMM-Domoticz
                            MMM-DailyBibleVerse is not used it´s just there
                            MMM-Domoticz is needed
                            I used this here from another Topic:
                            @Snille said in How to update.:
                            @izanbard Hello, added a restart of the mirror (via pm2) if an npm install has been done and also added “–production” to the npm install command. Sometimes the module-developer have lot’s of extra stuff added in the package list just for developing. :)
                            I’m currently now running this script via CRON every night. :)
                            #!/usr/bin/env bash
                            updated=false
                            cd /home/pi/MagicMirror
                            echo "Checking for MagicMirror updates."
                            git fetch
                            if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]
                            then
                                echo "Found, updating..."
                                git pull
                                npm install
                                updated=true
                                echo "Update done."
                            else
                                echo "No update needed."
                            fi
                            echo ""
                            cd modules
                            for directory in *; do
                                if [[ -d ${directory} && ${directory} != "node_modules" && ${directory} != "default" ]]; then
                                    echo "Checking for ${directory} updates."
                                    cd ${directory}
                                    git fetch
                                    if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]; then
                                        echo "Found, updating ${directory}..."
                                        git pull
                                        if [[ -e "package.json" && -f "package.json" ]]; then
                                            echo "package.joson changed for ${directory}, installing..."
                                            npm install --production
                                            updated=true
                                            echo "Update done."
                                        fi
                                    else
                                    fi
                                    echo ""
                                    cd ..
                                fi
                            done
                            if $updated; then
                                echo "Restart of MM needed, restarting now."
                                pm2 restart mm
                            fi
                            echo "All done. :)"
                            maybe it was a failure …
                            if I try:
                            pi@magicmirror:~/MagicMirror $ ./run-start.sh
                            maybe this helps?
                              sdetweil @mastadook
                              @mastadook run-start.sh wasn’t meant to be executed directly… it depended on npm to setup the path
                              but you can fix this,
                              get the latest
                              cd ~/MagicMirror
                              curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                              or
                              u can edit the line in the script that is changed
                              add the path (node_modules/.bin/) to the invocation of electron like below
                              note the dot in front of bin
                                else
                                  # we can use electron directly
                                  node_modules/.bin/electron js/electron.js $1;
                                fi
                              can u show me the output of pm2 show mm
                              • M
                                mastadook
                                yes, here is the Output you ask me:
                                pi@magicmirror:~ $ pm2 show 0
                                 Describing process with id 0 - name MagicMirror
                                │ status            │ online                                   │
                                │ name              │ MagicMirror                              │
                                │ version           │ 2.10.1                                   │
                                │ restarts          │ 10                                       │
                                │ uptime            │ 3s                                       │
                                │ script path       │ /home/pi/MagicMirror                     │
                                │ script args       │ N/A                                      │
                                │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
                                │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
                                │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
                                │ interpreter       │ node                                     │
                                │ interpreter args  │ N/A                                      │
                                │ script id         │ 0                                        │
                                │ exec cwd          │ /home/pi                                 │
                                │ exec mode         │ fork_mode                                │
                                │ node.js version   │ 10.18.1                                  │
                                │ node env          │ N/A                                      │
                                │ watch & reload    │ ✘                                        │
                                │ unstable restarts │ 0                                        │
                                │ created at        │ 2020-02-05T12:09:50.536Z                 │
                                 Actions available
                                │ km:heapdump            │
                                │ km:cpu:profiling:start │
                                │ km:cpu:profiling:stop  │
                                │ km:heap:sampling:start │
                                │ km:heap:sampling:stop  │
                                 Trigger via: pm2 trigger MagicMirror <action_name>
                                 Divergent env variables from local env
                                 Add your own code metrics: http://bit.ly/code-metrics
                                 Use `pm2 logs MagicMirror [--lines 1000]` to display logs
                                 Use `pm2 env 0` to display environement variables
                                 Use `pm2 monit` to monitor CPU and Memory usage MagicMirror
                                after change run-start.sh the error Message disappeared.
                                But start with pm2 is still not possible.
                                  sdetweil @mastadook
                                  in folder
                                       /home/pi
                                  start this
                                  do this
                                  pm2 delete 0
                                  • M
                                    mastadook
                                    @sdetweil said in update magic mirror:
                                    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                                    Great :)
                                    I think you did it.
                                    pi@magicmirror:~/MagicMirror $ pm2 show 0
                                    │ status            │ online                                   │
                                    │ restarts          │ 0                                        │
                                    │ uptime            │ 40s                                      │
                                    │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
                                    │ interpreter       │ bash                                     │
                                    │ script id         │ 0                                        │
                                    │ exec cwd          │ /home/pi/MagicMirror                     │
                                    │ node.js version   │ N/A                                      │
                                    │ node env          │ N/A                                      │
                                    │ watch & reload    │ ✔                                        │
                                    │ created at        │ 2020-02-05T15:00:22.116Z                 │
                                     Revision control metadata
                                    │ revision control │ git                                                │
                                    │ remote url       │ https://github.com/MichMich/MagicMirror.git        │
                                    │ repository root  │ /home/pi/MagicMirror                               │
                                    │ last update      │ 2020-02-05T15:00:23.257Z                           │
                                    │ revision         │ 5bf90ae31d600e3f595ffd242b99515fa7905b1a           │
                                    │ comment          │ Merge pull request #1872 from MichMich/2.10.1-docs │
                                    │                  │ 2.10.1 docs                                        │
                                    │ branch           │ master                                             │
                                    │ SHLVL  │ 2                    │
                                    │ OLDPWD │ /home/pi/MagicMirror │
                                    No restarts. It seems to run fine now.
                                    Will it start automatically now?
                                    And Update now with git pull && npm install?
                                    Thank you for your help!
                                      sdetweil @mastadook
                                      @mastadook use my upgrade script… see here
                                      while sometimes its ok to do the git pull/npm install, sometimes its not (as dependencies impact running modules)…
                                        sdetweil @mastadook
                                        @mastadook should, reboot…
                                        • M
                                          mastadook
                                          Thank you, all works fine now
                                          Best Regards
                                            sdetweil @mastadook
                                            @mastadook cool. Glad you got it!
