Solved update magic mirror
hi !
Today i have a problem with the update. The screen show the message “an update is available, need 4 commits”, but when i do the command on the readme, my terminal say “no module found needing npm refresh” and many error about save_custom.css.
More, i would like know if they are something to do to make automatic installation update .
best regards -
@mastadook ok, you are starting in the wrong place with the wrong script…
in folder /home/pi start this /home/pi/MagicMirror
use my pm2 fixup script…
do this
pm2 delete 0 bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
@Raxos I think you are running the upgrade script? if so, can u show me the
~/MagicMirror/installers/upgrade.log
that message means there are no active installed modules (in the modules folder) which contain a package.json file
i use the command bash -c “$(curl -sl https://raw.gitusercontent/miuchmich/magicmirror/master/installers/upgrade-script.sh)”
the log : https://drive.google.com/open?id=1t1eFgTcRHwEFOalFnfDFjbiW5g80V6VT
@Raxos that link is not valid. The scripts have been moved to an external site for a few weeks now. (That exact script has a fatal bug)
See the scripts here
https://github.com/sdetweil/MagicMirror_scriptsAlso, the Google drive link is not shared.
okay, so if i understand, i nedd to do bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
the log: https://drive.google.com/file/d/1t1eFgTcRHwEFOalFnfDFjbiW5g80V6VT/view?usp=sharing
@Raxos ok, can you execute these commands and tell me the results
LC_ALL=C git status locale
after Update I have this Problem: Any Idea?
0|MagicMirror | > magicmirror@2.10.1 start /home/pi/MagicMirror
0|MagicMirror | > ./run-start.sh
0|MagicMirror | ./run-start.sh: Zeile 66: electron: Kommando nicht gefunden.
0|MagicMirror | npm
0|MagicMirror | ERR! code ELIFECYCLE
0|MagicMirror | npm
0|MagicMirror | ERR! syscall spawn
0|MagicMirror | npm ERR! file
0|MagicMirror | sh
0|MagicMirror | npm ERR! errno ENOENT
0|MagicMirror | npm
0|MagicMirror | ERR! magicmirror@2.10.1 start:./run-start.sh
0|MagicMirror | npm ERR! spawn ENOENT
0|MagicMirror | npm
0|MagicMirror | ERR! Failed at the magicmirror@2.10.1 start script.
0|MagicMirror | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
0|MagicMirror | npm ERR! A complete log of this run can be found in:
0|MagicMirror | npm ERR! /home/pi/.npm/_logs/2020-01-31T15_08_06_616Z-debug.logWhat can I do?
Regards
Clemens -
@mastadook can u tell us more?
What version did u upgrade from?Show output of
uname
npm -v
node -v -
Hi Sam,
here are the requested Infos:
pi@magicmirror:~ $ uname
Linux
pi@magicmirror:~ $ npm -v
6.13.4
pi@magicmirror:~ $ node -v
v10.18.1Errormessage after npm install
0|MagicMirror | path: ‘package.json’ }
0|MagicMirror | [15:31:05.578] [ERROR]
0|MagicMirror | { Error: ENOENT: no such file or directory, open ‘package.json’
0|MagicMirror | at Object.openSync (fs.js:443:3)
0|MagicMirror | at Object.readFileSync (fs.js:343:35)
0|MagicMirror | at Object. (/home/pi/MagicMirror/js/app.js:21:32)
0|MagicMirror | at Module._compile (internal/modules/cjs/loader.js:778:30)
0|MagicMirror | at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
0|MagicMirror | at Module.load (internal/modules/cjs/loader.js:653:32)
0|MagicMirror | at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
0|MagicMirror | at Function.Module._load (internal/modules/cjs/loader.js:585:3)
0|MagicMirror | at Module.require (internal/modules/cjs/loader.js:692:17)
0|MagicMirror | at Module.Hook._require.Module.require (/usr/lib/node_modules/pm2/node_modules/require-in-the-middle/index.js:70:39)
0|MagicMirror | errno: -2,
0|MagicMirror | syscall: ‘open’,
0|MagicMirror | code: ‘ENOENT’,It works for some hours, after restart the Errormessage comes back.
@mastadook said in update magic mirror:
can u tell me what modules u have installed? (folder names in MagicMirror/modules, excluding default)
there is one module I know of that uses pm2 to launch another component under the covers
how did u upgrade to 2.10.1?
