    update magic mirror
    19 Posts 3 Posters 6.9k Views 3 Watching
      sdetweil @mastadook
      @mastadook said in update magic mirror:
      /usr/lib/node_modules/pm2/node_
      can u tell me what modules u have installed? (folder names in MagicMirror/modules, excluding default)
      there is one module I know of that uses pm2 to launch another component under the covers
      how did u upgrade to 2.10.1?
        mastadook
        Hi
        pi@magicmirror:~/MagicMirror/modules $ ls
        default MMM-DailyBibleVerse MMM-Domoticz
        MMM-DailyBibleVerse is not used it´s just there
        MMM-Domoticz is needed
        I used this here from another Topic:
        @Snille said in How to update.:
        @izanbard Hello, added a restart of the mirror (via pm2) if an npm install has been done and also added “–production” to the npm install command. Sometimes the module-developer have lot’s of extra stuff added in the package list just for developing. :)
        I’m currently now running this script via CRON every night. :)
        #!/usr/bin/env bash
        updated=false
        cd /home/pi/MagicMirror
        echo "Checking for MagicMirror updates."
        git fetch
        if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]
        then
            echo "Found, updating..."
            git pull
            npm install
            updated=true
            echo "Update done."
        else
            echo "No update needed."
        fi
        echo ""
        cd modules
        for directory in *; do
            if [[ -d ${directory} && ${directory} != "node_modules" && ${directory} != "default" ]]; then
                echo "Checking for ${directory} updates."
                cd ${directory}
                git fetch
                if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]; then
                    echo "Found, updating ${directory}..."
                    git pull
                    if [[ -e "package.json" && -f "package.json" ]]; then
                        echo "package.joson changed for ${directory}, installing..."
                        npm install --production
                        updated=true
                        echo "Update done."
                    fi
                else
                fi
                echo ""
                cd ..
            fi
        done
        if $updated; then
            echo "Restart of MM needed, restarting now."
            pm2 restart mm
        fi
        echo "All done. :)"
        maybe it was a failure …
        if I try:
        pi@magicmirror:~/MagicMirror $ ./run-start.sh
        ./run-start.sh: Zeile 66: electron: Kommando nicht gefunden.
        maybe this helps?
          sdetweil @mastadook
          @mastadook run-start.sh wasn’t meant to be executed directly… it depended on npm to setup the path
          but you can fix this,
          get the latest
          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
          or
          u can edit the line in the script that is changed
          add the path (node_modules/.bin/) to the invocation of electron like below
          note the dot in front of bin
            else
              # we can use electron directly
              node_modules/.bin/electron js/electron.js $1;
            fi
          can u show me the output of pm2 show mm
            mastadook
            yes, here is the Output you ask me:
            pi@magicmirror:~ $ pm2 show 0
             Describing process with id 0 - name MagicMirror
            │ status            │ online                                   │
            │ name              │ MagicMirror                              │
            │ version           │ 2.10.1                                   │
            │ restarts          │ 10                                       │
            │ uptime            │ 3s                                       │
            │ script path       │ /home/pi/MagicMirror                     │
            │ script args       │ N/A                                      │
            │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
            │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
            │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
            │ interpreter       │ node                                     │
            │ interpreter args  │ N/A                                      │
            │ script id         │ 0                                        │
            │ exec cwd          │ /home/pi                                 │
            │ exec mode         │ fork_mode                                │
            │ node.js version   │ 10.18.1                                  │
            │ node env          │ N/A                                      │
            │ watch & reload    │ ✘                                        │
            │ unstable restarts │ 0                                        │
            │ created at        │ 2020-02-05T12:09:50.536Z                 │
             Actions available
            │ km:heapdump            │
            │ km:cpu:profiling:start │
            │ km:cpu:profiling:stop  │
            │ km:heap:sampling:start │
            │ km:heap:sampling:stop  │
             Trigger via: pm2 trigger MagicMirror <action_name>
             Divergent env variables from local env
             Add your own code metrics: http://bit.ly/code-metrics
             Use `pm2 logs MagicMirror [--lines 1000]` to display logs
             Use `pm2 env 0` to display environement variables
             Use `pm2 monit` to monitor CPU and Memory usage MagicMirror
            after change run-start.sh the error Message disappeared.
            But start with pm2 is still not possible.
              sdetweil @mastadook
              @mastadook ok, you are starting in the wrong place with the wrong script…
              in folder
                   /home/pi
              start this
              use my pm2 fixup script…
              do this
              pm2 delete 0
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                mastadook
                @sdetweil said in update magic mirror:
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                Great :)
                I think you did it.
                pi@magicmirror:~/MagicMirror $ pm2 show 0
                │ status            │ online                                   │
                │ restarts          │ 0                                        │
                │ uptime            │ 40s                                      │
                │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
                │ interpreter       │ bash                                     │
                │ script id         │ 0                                        │
                │ exec cwd          │ /home/pi/MagicMirror                     │
                │ node.js version   │ N/A                                      │
                │ node env          │ N/A                                      │
                │ watch & reload    │ ✔                                        │
                │ created at        │ 2020-02-05T15:00:22.116Z                 │
                 Revision control metadata
                │ revision control │ git                                                │
                │ remote url       │ https://github.com/MichMich/MagicMirror.git        │
                │ repository root  │ /home/pi/MagicMirror                               │
                │ last update      │ 2020-02-05T15:00:23.257Z                           │
                │ revision         │ 5bf90ae31d600e3f595ffd242b99515fa7905b1a           │
                │ comment          │ Merge pull request #1872 from MichMich/2.10.1-docs │
                │                  │ 2.10.1 docs                                        │
                │ branch           │ master                                             │
                │ SHLVL  │ 2                    │
                │ OLDPWD │ /home/pi/MagicMirror │
                No restarts. It seems to run fine now.
                Will it start automatically now?
                And Update now with git pull && npm install?
                Thank you for your help!
                S 2 Replies Last reply
                  sdetweil @mastadook
                  @mastadook use my upgrade script… see here
                  while sometimes its ok to do the git pull/npm install, sometimes its not (as dependencies impact running modules)…
                    sdetweil @mastadook
                    @mastadook should, reboot…
                      mastadook
                      Thank you, all works fine now
                      Best Regards
                        sdetweil @mastadook
                        @mastadook cool. Glad you got it!
