    MMM-soccer v2
    Scheduled Pinned Locked Moved Sport
    51 Posts 8 Posters 22.2k Views 8 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @lavolp3
      @lavolp3 should be fixed now. Only one css line
      Again, please do a git pull
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        matze86 @lavolp3
        @lavolp3
        I fixed it by my own
        I can send you the css of you want
        Is ist possible to delete the last games of my team?
        I only found a Solution to reduce it from 3 to 2 , by editing line 247 (changing the number in bracktes), but each other Number than 3 will only reduce it to 2 Games
        • lavolp3L Offline
          lavolp3 Module Developer @matze86
          @matze86 Change line 249 in MMM-soccer.js from
          for (var i = index - 1; i < filteredMatches.length; i++) {
                              nextMatches.push(filteredMatches[i]);
          to
          for (var i = index; i < filteredMatches.length; i++) {
          (Remove the “- 1”)
            matze86 @lavolp3
            @lavolp3
            i changed it to “+ 1”, because with with i = index it will still display the last game. Or when will the module update the game list? i think on the next matchday?
            • lavolp3L Offline
              @matze86
              Hm. The module has a range of future and recent games.
              Then it searches for the index of the first game after the current date.
              THen takes that value as index, so index should be the next game, index-1 the last and index+1 the one after the next.
              Does your workaround actually work?
              Then I’m thinking wrong.
                matze86 @lavolp3
                @lavolp3
                On monday it still displayed the last Game with „Index“
                Today it works as you described. So this is the best Solution (for me)
                next
                Other Topic:
                league
                When will the matchday in „league“ change to the next?
                Is it possible to add More columns to the table like this? Or to add up/down arrows? Or to add further Information like CL-Position/EL-Position and so on?
                lavolp3L 1 Reply Last reply Reply Quote 1
                • lavolp3L Offline
                  @matze86 said in MMM-soccer v2:
                  I added played games as a column just today . Up and down arrows are a good idea but I need to check if the API gives the most recent table. I don’t think so.
                  Good idea!
                  They positions (relegation, qualifications) is most probably not possible.
                  I’ll check.
                    matze86 @lavolp3
                    @lavolp3
                    Great! I‘ll Update the Module soon
                    Maybe with a different colour for the Position?
                    • lavolp3L Offline
                      @lavolp3
                      So I checked the API output. Unfortunately we don’t have a reference for the recent table position.
                      "table": [{
                      	"position": 1,
                      	"team": {
                      		"id": 5,
                      		"name": "FC Bayern München",
                      		"crestUrl": "https://crests.football-data.org/5.svg"
                      	"playedGames": 26,
                      	"form": "W,W,W,W,L",
                      	"won": 19,
                      	"draw": 4,
                      	"lost": 3,
                      	"points": 61,
                      	"goalsFor": 78,
                      	"goalsAgainst": 35,
                      	"goalDifference": 43
                      We would have to call the API again for the last matchday’s table, which consumes API calls.
                      I’m not sure if I want that.
                      I still very much like the idea however.
                      Also, you can see there’s no reference to relegation or qualification ranks
                        matze86 @lavolp3
                        @lavolp3
                        Allright… Too Bad…
                        Here you can see my momentary Soccer Dashboard. I copied your module three times with different configs.
                        But i‘m Not statisfied with the Symbols of fontawesome. Are there other Styles possible?
                        I think the api also does Not give the Information about the time of Match?
                        • 6
                        • 4 / 6
