    MMM-soccer v2
    Scheduled Pinned Locked Moved Sport
    52 Posts 9 Posters 29.4k Views 9 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @matze86
      @matze86 said in MMM-soccer v2:
      I think the api also does Not give the Information about the time of Match?
      It does.
      Usually APIs work with timestamps or date strings including date and time.
      My module is set to only show the time at the day of match. It does not show date AND time due to limited space.
      if (match.status == "SCHEDULED" || match.status == "POSTPONED") {
                          match.state = (moment(match.utcDate).diff(moment(), 'days') > 7) ? moment(match.utcDate).format("D.MM.") : (moment(match.utcDate).startOf('day') > moment()) ? moment(match.utcDate).format("dd") : moment(match.utcDate).format("LT");
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        matze86 @lavolp3
        @lavolp3
        thx. now i’ll come closer to a perfect overview :thumbs_up:
        • E Offline
          Egnos
          Hi @lavolp3 I downloaded your module from here:
          https://bytemeta.vip/repo/lavolp3/MMM-soccer
          But for some reason the results of the Champions League do not show the logos of the teams and also the results seem to me formatted badly.
          Am I doing something wrong?
          Follow a screenshot:
          2022-09-01-135409-3280x1050-scrot
          Here is the config.js:
              module: 'MMM-soccer',
              position: 'top_right',
                  api_key: '2c709c5e9c9a491a88b810c43ae00f0e',
                  show: ['SA'],
                  colored: true,
                  logos: true,
                  updateInterval: 60,
                  showTables: false,
                  focus_on: {
          			'SA': 'FC Juventus'
                  max_teams: 5,
                  matchType: 'league'
              position: 'top_left',
                  show: ['CL'],
                  logos: true,
                  colored: true,
                  updateInterval: 60,
                  focus_on: {
          			'CL': 'FC Juventus'
                  max_teams: 5,
                  matchType: 'league'
          Thanks.
          • thymonT Offline
            thymon
            Hello,
            the same here with FL1 league.
            thymonT 1 Reply Last reply Reply Quote 0
            • thymonT Offline
              thymon @thymon
              Hello @lavolp3 !
              Please don’t let this “module” die. You are the last.
              You are Highlander !! :D
              lavolp3L 1 Reply Last reply Reply Quote 1
              • lavolp3L Offline
                lavolp3 Module Developer @thymon
                @thymon thanks thymon for the wake up call. I am updating the module right now. Logos already work again. Stay tuned!
                • lavolp3L Offline
                  lavolp3 Module Developer @lavolp3
                  @thymon
                  please do a git pull and check out.
                  Hope it works!
                  Got a bit rusty on the programming after 3 years…
                  • thymonT Offline
                    thymon @lavolp3
                    @lavolp3
                    Finally, you are not rusty.
                    Because everything works now.
                    Thank you so much for your responsiveness!
                    Is-it possible to add “fr.json” translation ?
                    "LOADING": "Chargement...",
                    "NO_DATA_AVAILABLE": "Aucune donnée disponible !",
                    "NO_MATCHES": "Aucune correspondance",
                    "TODAYS_MATCHES": "Aujourd'hui",
                    "NEXT_MATCHES": "Prochains matchs",
                    "MATCHDAY": "Jour de match",
                    "TEAM": "Équipe",
                    "COMMAND_LIST": "Liste de toutes les commandes vocales",
                    "MODE": "Mode",
                    "VOICE_COMMANDS": "Commandes vocales",
                    "PLAY_OFF_ROUND": "Tour de barrages",
                    "ROUND_OF_16": "Huitièmes de finale",
                    "ROUND_OF_8": "Quarts de finale",
                    "ROUND_OF_4": "Demi-finales",
                    "FINAL": "Finales"
                    • lavolp3L Offline
                      @thymon for sure it is, but will need a few days probably
                      • thymonT Offline
                        thymon @lavolp3
                        @lavolp3 Great !
                        • E Offline
                          Egnos
                          @lavolp3 is there a way to hide the league tables?
                          thanks
                          • NiggichN Offline
                            Niggich
                            Hey @lavolp3,
                            thank you for the nice module. Is there a way to change the header from ‘MMM-Soccer’ to smth else? I’ve tried to set the header in the config.js but then I have two header. My one an the ‘MMM-Soccer’ header. THX
                            Edit: I found a way. It’s not the finest solution but it works. I changed the header in the ‘MMM-soccer.njk’ file.
                            • 3 / 3
