    MMM-soccer v2
    52 Posts 9 Posters 37.2k Views 9 Watching
      matze86 @lavolp3
      @lavolp3
      i changed it to “+ 1”, because with with i = index it will still display the last game. Or when will the module update the game list? i think on the next matchday?
      lavolp3L 1 Reply Last reply
      • lavolp3L
        lavolp3 Module Developer @matze86
        @matze86
        Hm. The module has a range of future and recent games.
        Then it searches for the index of the first game after the current date.
        THen takes that value as index, so index should be the next game, index-1 the last and index+1 the one after the next.
        Does your workaround actually work?
        Then I’m thinking wrong.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        M 1 Reply Last reply
          matze86 @lavolp3
          @lavolp3
          On monday it still displayed the last Game with „Index“
          Today it works as you described. So this is the best Solution (for me)
          next
          Other Topic:
          league
          When will the matchday in „league“ change to the next?
          Is it possible to add More columns to the table like this? Or to add up/down arrows? Or to add further Information like CL-Position/EL-Position and so on?
          • lavolp3L
            @matze86 said in MMM-soccer v2:
            I added played games as a column just today . Up and down arrows are a good idea but I need to check if the API gives the most recent table. I don’t think so.
            Good idea!
            They positions (relegation, qualifications) is most probably not possible.
            I’ll check.
              matze86 @lavolp3
              @lavolp3
              Great! I‘ll Update the Module soon
              Maybe with a different colour for the Position?
              • lavolp3L
                @lavolp3
                So I checked the API output. Unfortunately we don’t have a reference for the recent table position.
                "table": [{
                	"position": 1,
                	"team": {
                		"id": 5,
                		"name": "FC Bayern München",
                		"crestUrl": "https://crests.football-data.org/5.svg"
                	"playedGames": 26,
                	"form": "W,W,W,W,L",
                	"won": 19,
                	"draw": 4,
                	"lost": 3,
                	"points": 61,
                	"goalsFor": 78,
                	"goalsAgainst": 35,
                	"goalDifference": 43
                We would have to call the API again for the last matchday’s table, which consumes API calls.
                I’m not sure if I want that.
                I still very much like the idea however.
                Also, you can see there’s no reference to relegation or qualification ranks
                  matze86 @lavolp3
                  @lavolp3
                  Allright… Too Bad…
                  Here you can see my momentary Soccer Dashboard. I copied your module three times with different configs.
                  But i‘m Not statisfied with the Symbols of fontawesome. Are there other Styles possible?
                  I think the api also does Not give the Information about the time of Match?
                  • lavolp3L
                    It does.
                    Usually APIs work with timestamps or date strings including date and time.
                    My module is set to only show the time at the day of match. It does not show date AND time due to limited space.
                    if (match.status == "SCHEDULED" || match.status == "POSTPONED") {
                                        match.state = (moment(match.utcDate).diff(moment(), 'days') > 7) ? moment(match.utcDate).format("D.MM.") : (moment(match.utcDate).startOf('day') > moment()) ? moment(match.utcDate).format("dd") : moment(match.utcDate).format("LT");
                      matze86 @lavolp3
                      @lavolp3
                      thx. now i’ll come closer to a perfect overview :thumbs_up:
                      • E
                        Egnos
                        Hi @lavolp3 I downloaded your module from here:
                        https://bytemeta.vip/repo/lavolp3/MMM-soccer
                        But for some reason the results of the Champions League do not show the logos of the teams and also the results seem to me formatted badly.
                        Am I doing something wrong?
                        Follow a screenshot:
                        2022-09-01-135409-3280x1050-scrot
                        Here is the config.js:
                            module: 'MMM-soccer',
                            position: 'top_right',
                                api_key: '2c709c5e9c9a491a88b810c43ae00f0e',
                                show: ['SA'],
                                colored: true,
                                logos: true,
                                updateInterval: 60,
                                showTables: false,
                                focus_on: {
                        			'SA': 'FC Juventus'
                                max_teams: 5,
                                matchType: 'league'
                            position: 'top_left',
                                show: ['CL'],
                                logos: true,
                                colored: true,
                                updateInterval: 60,
                                focus_on: {
                        			'CL': 'FC Juventus'
                                max_teams: 5,
                                matchType: 'league'
                        Thanks.
                        • thymonT
                          thymon
                          the same here with FL1 league.
                          thymonT 1 Reply Last reply
                          • thymonT
                            thymon @thymon
                            Hello @lavolp3 !
                            Please don’t let this “module” die. You are the last.
                            You are Highlander !! :D
                            • lavolp3L
                              lavolp3 Module Developer @thymon
                              @thymon thanks thymon for the wake up call. I am updating the module right now. Logos already work again. Stay tuned!
                              • lavolp3L
                                lavolp3 Module Developer @lavolp3
                                @thymon
                                please do a git pull and check out.
                                Hope it works!
                                Got a bit rusty on the programming after 3 years…
                                • thymonT
                                  thymon @lavolp3
                                  @lavolp3
                                  Finally, you are not rusty.
                                  Because everything works now.
                                  Thank you so much for your responsiveness!
                                  Is-it possible to add “fr.json” translation ?
                                  "LOADING": "Chargement...",
                                  "NO_DATA_AVAILABLE": "Aucune donnée disponible !",
                                  "NO_MATCHES": "Aucune correspondance",
                                  "TODAYS_MATCHES": "Aujourd'hui",
                                  "NEXT_MATCHES": "Prochains matchs",
                                  "MATCHDAY": "Jour de match",
                                  "TEAM": "Équipe",
                                  "COMMAND_LIST": "Liste de toutes les commandes vocales",
                                  "MODE": "Mode",
                                  "VOICE_COMMANDS": "Commandes vocales",
                                  "PLAY_OFF_ROUND": "Tour de barrages",
                                  "ROUND_OF_16": "Huitièmes de finale",
                                  "ROUND_OF_8": "Quarts de finale",
                                  "ROUND_OF_4": "Demi-finales",
                                  "FINAL": "Finales"
                                  • lavolp3L
                                    @thymon for sure it is, but will need a few days probably
                                    • thymonT
                                      thymon @lavolp3
                                      @lavolp3 Great !
                                      • E
                                        Egnos
                                        @lavolp3 is there a way to hide the league tables?
                                        thanks
                                        • NiggichN
                                          Niggich
                                          Hey @lavolp3,
                                          thank you for the nice module. Is there a way to change the header from ‘MMM-Soccer’ to smth else? I’ve tried to set the header in the config.js but then I have two header. My one an the ‘MMM-Soccer’ header. THX
                                          Edit: I found a way. It’s not the finest solution but it works. I changed the header in the ‘MMM-soccer.njk’ file.
                                          • 3 / 3
