    MMM-soccer v2
    52 Posts 9 Posters 36.9k Views 9 Watching
    • lavolp3L
      lavolp3 Module Developer @matze86
      @matze86 ok I’ll check that error.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • lavolp3L
        @matze86 OK i pushed a fix.
        Please do a git pull and let me know if it works better now.
        M 1 Reply Last reply
          matze86 @lavolp3
          @lavolp3
          It worked! Very nice! Thx a lot👍🏻
          Now i‘m „fighting“ with the css and the alignment in the table. See the picture for more Details
          lavolp3L 1 Reply Last reply
          • lavolp3L
            @matze86 yeah another issue i have just now realized. Give me a bit of time.
            lavolp3L M 2 Replies Last reply
            • lavolp3L
              lavolp3 Module Developer @lavolp3
              @lavolp3 should be fixed now. Only one css line
              Again, please do a git pull
                matze86 @lavolp3
                @lavolp3
                I fixed it by my own
                I can send you the css of you want
                Is ist possible to delete the last games of my team?
                I only found a Solution to reduce it from 3 to 2 , by editing line 247 (changing the number in bracktes), but each other Number than 3 will only reduce it to 2 Games
                • lavolp3L
                  @matze86 Change line 249 in MMM-soccer.js from
                  for (var i = index - 1; i < filteredMatches.length; i++) {
                                      nextMatches.push(filteredMatches[i]);
                  to
                  for (var i = index; i < filteredMatches.length; i++) {
                  (Remove the “- 1”)
                    matze86 @lavolp3
                    @lavolp3
                    i changed it to “+ 1”, because with with i = index it will still display the last game. Or when will the module update the game list? i think on the next matchday?
                    • lavolp3L
                      @matze86
                      Hm. The module has a range of future and recent games.
                      Then it searches for the index of the first game after the current date.
                      THen takes that value as index, so index should be the next game, index-1 the last and index+1 the one after the next.
                      Does your workaround actually work?
                      Then I’m thinking wrong.
                        matze86 @lavolp3
                        @lavolp3
                        On monday it still displayed the last Game with „Index“
                        Today it works as you described. So this is the best Solution (for me)
                        next
                        Other Topic:
                        league
                        When will the matchday in „league“ change to the next?
                        Is it possible to add More columns to the table like this? Or to add up/down arrows? Or to add further Information like CL-Position/EL-Position and so on?
                        • lavolp3L
                          @matze86 said in MMM-soccer v2:
                          I added played games as a column just today . Up and down arrows are a good idea but I need to check if the API gives the most recent table. I don’t think so.
                          Good idea!
                          They positions (relegation, qualifications) is most probably not possible.
                          I’ll check.
                            matze86 @lavolp3
                            @lavolp3
                            Great! I‘ll Update the Module soon
                            Maybe with a different colour for the Position?
                            • lavolp3L
                              @lavolp3
                              So I checked the API output. Unfortunately we don’t have a reference for the recent table position.
                              "table": [{
                              	"position": 1,
                              	"team": {
                              		"id": 5,
                              		"name": "FC Bayern München",
                              		"crestUrl": "https://crests.football-data.org/5.svg"
                              	"playedGames": 26,
                              	"form": "W,W,W,W,L",
                              	"won": 19,
                              	"draw": 4,
                              	"lost": 3,
                              	"points": 61,
                              	"goalsFor": 78,
                              	"goalsAgainst": 35,
                              	"goalDifference": 43
                              We would have to call the API again for the last matchday’s table, which consumes API calls.
                              I’m not sure if I want that.
                              I still very much like the idea however.
                              Also, you can see there’s no reference to relegation or qualification ranks
                                matze86 @lavolp3
                                @lavolp3
                                Allright… Too Bad…
                                Here you can see my momentary Soccer Dashboard. I copied your module three times with different configs.
                                But i‘m Not statisfied with the Symbols of fontawesome. Are there other Styles possible?
                                I think the api also does Not give the Information about the time of Match?
                                • lavolp3L
                                  It does.
                                  Usually APIs work with timestamps or date strings including date and time.
                                  My module is set to only show the time at the day of match. It does not show date AND time due to limited space.
                                  if (match.status == "SCHEDULED" || match.status == "POSTPONED") {
                                                      match.state = (moment(match.utcDate).diff(moment(), 'days') > 7) ? moment(match.utcDate).format("D.MM.") : (moment(match.utcDate).startOf('day') > moment()) ? moment(match.utcDate).format("dd") : moment(match.utcDate).format("LT");
                                    matze86 @lavolp3
                                    @lavolp3
                                    thx. now i’ll come closer to a perfect overview :thumbs_up:
                                    • E
                                      Egnos
                                      Hi @lavolp3 I downloaded your module from here:
                                      https://bytemeta.vip/repo/lavolp3/MMM-soccer
                                      But for some reason the results of the Champions League do not show the logos of the teams and also the results seem to me formatted badly.
                                      Am I doing something wrong?
                                      Follow a screenshot:
                                      2022-09-01-135409-3280x1050-scrot
                                      Here is the config.js:
                                          module: 'MMM-soccer',
                                          position: 'top_right',
                                              api_key: '2c709c5e9c9a491a88b810c43ae00f0e',
                                              show: ['SA'],
                                              colored: true,
                                              logos: true,
                                              updateInterval: 60,
                                              showTables: false,
                                              focus_on: {
                                      			'SA': 'FC Juventus'
                                              max_teams: 5,
                                              matchType: 'league'
                                          position: 'top_left',
                                              show: ['CL'],
                                              logos: true,
                                              colored: true,
                                              updateInterval: 60,
                                              focus_on: {
                                      			'CL': 'FC Juventus'
                                              max_teams: 5,
                                              matchType: 'league'
                                      Thanks.
                                      • thymonT
                                        thymon
                                        the same here with FL1 league.
                                        thymonT 1 Reply Last reply
                                        • thymonT
                                          thymon @thymon
                                          Hello @lavolp3 !
                                          Please don’t let this “module” die. You are the last.
                                          You are Highlander !! :D
                                          • lavolp3L
                                            lavolp3 Module Developer @thymon
                                            @thymon thanks thymon for the wake up call. I am updating the module right now. Logos already work again. Stay tuned!
                                            • 2 / 3
