    • MagicMirrorÂČ Repository
    MMM-soccer v2
    52 Posts 9 Posters 36.9k Views 9 Watching
      matze86 @lavolp3
      Hey @lavolp3
      I want to show the next matches of my team and this doesn’t work.
      If I change ‘league’ to ‘next’ (or ‘daily’) the screen displays only the header of the league table ("teams, games & goal difference).
      focus_on in combination with " matchtype: ‘league’ " works. My team is highlighted. (see the first config):
          module: 'MMM-soccer',
          position: 'top_right',
             api_key: 'my api',
             show: ['BL1'],
             colored: true,
             focus_on: {
      	     'BL1': 'FC Bayern MĂŒnchen',
             matchType: 'league'
      here is my “next” config of this module, which doesn’t work.
             api_key: 'my api',
             show: ['BL1'],
             colored: true,
             focus_on: {
             matchType: 'next',
             numberOfNextMatches: 5
      lavolp3L 2 Replies Last reply
      • lavolp3L
        lavolp3 Module Developer @matze86
        @matze86 The setup works for me and shows me the next 5 matches of Bayern MĂŒnchen.
        It actually also shows the last match so I might have to check that.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L
          @matze86 CAn you open the magicmirror page in your browser and check the developer’s tools (f12 --> console) for any errors?
          You might also activate debug mode in your config (debug: true) to get more output from the module.
          M 2 Replies Last reply
            matze86 @lavolp3
            @lavolp3
            i tried to start my mirror n server mode, but than i got these errors
            17.03.2021 20:05.53.544] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
            was compiled against a different Node.js version using
            NODE_MODULE_VERSION 76. This version of Node.js requires
            NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
            the module (for instance, using `npm rebuild` or `npm install`).
            [17.03.2021 20:05.53.547] [LOG]   Loading module helpers ...
            [17.03.2021 20:05.53.550] [LOG]   No helper found for module: alert.
            [17.03.2021 20:05.53.551] [LOG]   Initializing new module helper ...
            [17.03.2021 20:05.53.551] [LOG]   Module helper loaded: updatenotification
            [17.03.2021 20:05.53.552] [LOG]   No helper found for module: clock.
            [17.03.2021 20:05.53.558] [ERROR] Whoops! There was an uncaught exception...
            [17.03.2021 20:05.53.563] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                at Object.Module._extensions..node (internal/modules/cjs/loader.js:1122:18)
                at Module.load (internal/modules/cjs/loader.js:928:32)
                at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                at Module.require (internal/modules/cjs/loader.js:952:19)
                at require (internal/modules/cjs/helpers.js:88:18)
                at bindings (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/bindings/bindings.js:112:48)
                at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:15:3)
                at Module._compile (internal/modules/cjs/loader.js:1063:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
            i reinstalled in the following order:
            the module “navigate”, npm, node.js, mirror software,
            but it doen’t change anything. i have to check this before i can try further
            with npm run start the mirror works well
              matze86 @lavolp3
              @lavolp3
              here is the output from the console
              MMM-soccer: "received a Socket Notification: MATCHES"
              MMM-soccer.js:432 MMM-soccer: "Calculating Team Display Boundaries"
              MMM-soccer.js:432 MMM-soccer: "Focus on Team"
              MMM-soccer.js:432 MMM-soccer: "Finding focus team for table..."
              MMM-soccer.js:432 MMM-soccer: "Focus Team found: FC Bayern MĂŒnchen"
              MMM-soccer.js:432 MMM-soccer: "No Focus Team found! Please check your entry!"
              ReferenceError: numberOfNextMatches is not defined
                  at Class.prepareMatches (MMM-soccer.js:232)
                  at Class.getTemplateData (MMM-soccer.js:182)
                  at module.js:89
                  at new Promise (<anonymous>)
                  at Class.getDom (module.js:86)
                  at main.js:114
                  at updateDom (main.js:113)
                  at Object.updateDom (main.js:551)
                  at Class.updateDom (module.js:364)
              Why did it say, that no focus team has found? It is highlighted in “league mode”
              Furthermore i did not edit the MMM-soccer.js. so i don’t have any idea, why numberOfNextMatches is not defined
              M 1 Reply Last reply
                matze86 @matze86
                i saw, that the focus for table was not found. thats correct. it is only highlighted in the current matchday
                • lavolp3L
                  @matze86 ok I’ll check that error.
                  • lavolp3L
                    @matze86 OK i pushed a fix.
                    Please do a git pull and let me know if it works better now.
                      matze86 @lavolp3
                      @lavolp3
                      It worked! Very nice! Thx a lotđŸ‘đŸ»
                      Now i‘m „fighting“ with the css and the alignment in the table. See the picture for more Details
                      lavolp3L 1 Reply Last reply
                      • lavolp3L
                        @matze86 yeah another issue i have just now realized. Give me a bit of time.
                        lavolp3L M 2 Replies Last reply
                        • lavolp3L
                          lavolp3 Module Developer @lavolp3
                          @lavolp3 should be fixed now. Only one css line
                          Again, please do a git pull
                            matze86 @lavolp3
                            @lavolp3
                            I fixed it by my own
                            I can send you the css of you want
                            Is ist possible to delete the last games of my team?
                            I only found a Solution to reduce it from 3 to 2 , by editing line 247 (changing the number in bracktes), but each other Number than 3 will only reduce it to 2 Games
                            • lavolp3L
                              @matze86 Change line 249 in MMM-soccer.js from
                              for (var i = index - 1; i < filteredMatches.length; i++) {
                                                  nextMatches.push(filteredMatches[i]);
                              to
                              for (var i = index; i < filteredMatches.length; i++) {
                              (Remove the “- 1”)
                                matze86 @lavolp3
                                @lavolp3
                                i changed it to “+ 1”, because with with i = index it will still display the last game. Or when will the module update the game list? i think on the next matchday?
                                • lavolp3L
                                  @matze86
                                  Hm. The module has a range of future and recent games.
                                  Then it searches for the index of the first game after the current date.
                                  THen takes that value as index, so index should be the next game, index-1 the last and index+1 the one after the next.
                                  Does your workaround actually work?
                                  Then I’m thinking wrong.
                                    matze86 @lavolp3
                                    @lavolp3
                                    On monday it still displayed the last Game with „Index“
                                    Today it works as you described. So this is the best Solution (for me)
                                    next
                                    Other Topic:
                                    league
                                    When will the matchday in „league“ change to the next?
                                    Is it possible to add More columns to the table like this? Or to add up/down arrows? Or to add further Information like CL-Position/EL-Position and so on?
                                    • lavolp3L
                                      @matze86 said in MMM-soccer v2:
                                      I added played games as a column just today . Up and down arrows are a good idea but I need to check if the API gives the most recent table. I don’t think so.
                                      Good idea!
                                      They positions (relegation, qualifications) is most probably not possible.
                                      I’ll check.
                                        matze86 @lavolp3
                                        @lavolp3
                                        Great! I‘ll Update the Module soon
                                        Maybe with a different colour for the Position?
                                        • lavolp3L
                                          @lavolp3
                                          So I checked the API output. Unfortunately we don’t have a reference for the recent table position.
                                          "table": [{
                                          	"position": 1,
                                          	"team": {
                                          		"id": 5,
                                          		"name": "FC Bayern MĂŒnchen",
                                          		"crestUrl": "https://crests.football-data.org/5.svg"
                                          	"playedGames": 26,
                                          	"form": "W,W,W,W,L",
                                          	"won": 19,
                                          	"draw": 4,
                                          	"lost": 3,
                                          	"points": 61,
                                          	"goalsFor": 78,
                                          	"goalsAgainst": 35,
                                          	"goalDifference": 43
                                          We would have to call the API again for the last matchday’s table, which consumes API calls.
                                          I’m not sure if I want that.
                                          I still very much like the idea however.
                                          Also, you can see there’s no reference to relegation or qualification ranks
                                            matze86 @lavolp3
                                            @lavolp3
                                            Allright
 Too Bad
                                            Here you can see my momentary Soccer Dashboard. I copied your module three times with different configs.
                                            But i‘m Not statisfied with the Symbols of fontawesome. Are there other Styles possible?
                                            I think the api also does Not give the Information about the time of Match?
                                            • 2 / 3
