    MMM-soccer v2
    52 Posts 9 Posters 34.8k Views 9 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @Stoffbeuteluwe
      @Stoffbeuteluwe Yes use the key that you have received and put it in your config and that’s it.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @lavolp3
        @lavolp3 thank you
          dirk-graetz
          Hi lavolp3,
          your module is crashing if showMatches = false
          kind regards
          • lavolp3L Offline
            lavolp3 Module Developer @dirk-graetz
            @dirk-graetz thanks! Will have a look into it. Have to admit that I am not good in debugging my modules.
            • N Offline
              Nero
              Does this show the Championship, Leagues 1 and 2 in England? Thanks
              • lavolp3L Offline
                lavolp3 Module Developer @Nero
                @Nero No, only Premier League for England.
                  matze86 @lavolp3
                  Hey @lavolp3
                  I want to show the next matches of my team and this doesn’t work.
                  If I change ‘league’ to ‘next’ (or ‘daily’) the screen displays only the header of the league table ("teams, games & goal difference).
                  focus_on in combination with " matchtype: ‘league’ " works. My team is highlighted. (see the first config):
                      module: 'MMM-soccer',
                      position: 'top_right',
                         api_key: 'my api',
                         show: ['BL1'],
                         colored: true,
                         focus_on: {
                  	     'BL1': 'FC Bayern München',
                         matchType: 'league'
                  here is my “next” config of this module, which doesn’t work.
                         api_key: 'my api',
                         show: ['BL1'],
                         colored: true,
                         focus_on: {
                         matchType: 'next',
                         numberOfNextMatches: 5
                  lavolp3L 2 Replies Last reply Reply Quote 0
                  • lavolp3L Offline
                    lavolp3 Module Developer @matze86
                    @matze86 The setup works for me and shows me the next 5 matches of Bayern München.
                    It actually also shows the last match so I might have to check that.
                    • lavolp3L Offline
                      @matze86 CAn you open the magicmirror page in your browser and check the developer’s tools (f12 --> console) for any errors?
                      You might also activate debug mode in your config (debug: true) to get more output from the module.
                        matze86 @lavolp3
                        @lavolp3
                        i tried to start my mirror n server mode, but than i got these errors…
                        17.03.2021 20:05.53.544] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                        was compiled against a different Node.js version using
                        NODE_MODULE_VERSION 76. This version of Node.js requires
                        NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                        the module (for instance, using `npm rebuild` or `npm install`).
                        [17.03.2021 20:05.53.547] [LOG]   Loading module helpers ...
                        [17.03.2021 20:05.53.550] [LOG]   No helper found for module: alert.
                        [17.03.2021 20:05.53.551] [LOG]   Initializing new module helper ...
                        [17.03.2021 20:05.53.551] [LOG]   Module helper loaded: updatenotification
                        [17.03.2021 20:05.53.552] [LOG]   No helper found for module: clock.
                        [17.03.2021 20:05.53.558] [ERROR] Whoops! There was an uncaught exception...
                        [17.03.2021 20:05.53.563] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
                            at Object.Module._extensions..node (internal/modules/cjs/loader.js:1122:18)
                            at Module.load (internal/modules/cjs/loader.js:928:32)
                            at Function.Module._load (internal/modules/cjs/loader.js:769:14)
                            at Module.require (internal/modules/cjs/loader.js:952:19)
                            at require (internal/modules/cjs/helpers.js:88:18)
                            at bindings (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/bindings/bindings.js:112:48)
                            at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:15:3)
                            at Module._compile (internal/modules/cjs/loader.js:1063:30)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
                        i reinstalled in the following order:
                        the module “navigate”, npm, node.js, mirror software,
                        but it doen’t change anything. i have to check this before i can try further…
                        with npm run start the mirror works well…
                          matze86 @lavolp3
                          @lavolp3
                          here is the output from the console
                          MMM-soccer: "received a Socket Notification: MATCHES"
                          MMM-soccer.js:432 MMM-soccer: "Calculating Team Display Boundaries"
                          MMM-soccer.js:432 MMM-soccer: "Focus on Team"
                          MMM-soccer.js:432 MMM-soccer: "Finding focus team for table..."
                          MMM-soccer.js:432 MMM-soccer: "Focus Team found: FC Bayern München"
                          MMM-soccer.js:432 MMM-soccer: "No Focus Team found! Please check your entry!"
                          ReferenceError: numberOfNextMatches is not defined
                              at Class.prepareMatches (MMM-soccer.js:232)
                              at Class.getTemplateData (MMM-soccer.js:182)
                              at module.js:89
                              at new Promise (<anonymous>)
                              at Class.getDom (module.js:86)
                              at main.js:114
                              at updateDom (main.js:113)
                              at Object.updateDom (main.js:551)
                              at Class.updateDom (module.js:364)
                          Why did it say, that no focus team has found? It is highlighted in “league mode”
                          Furthermore i did not edit the MMM-soccer.js. so i don’t have any idea, why numberOfNextMatches is not defined
                            matze86 @matze86
                            i saw, that the focus for table was not found. thats correct. it is only highlighted in the current matchday…
                            • lavolp3L Offline
                              @matze86 ok I’ll check that error.
                              • lavolp3L Offline
                                @matze86 OK i pushed a fix.
                                Please do a git pull and let me know if it works better now.
                                  matze86 @lavolp3
                                  @lavolp3
                                  It worked! Very nice! Thx a lot👍🏻
                                  Now i‘m „fighting“ with the css and the alignment in the table. See the picture for more Details
                                  • lavolp3L Offline
                                    @matze86 yeah another issue i have just now realized. Give me a bit of time.
                                    lavolp3L M 2 Replies Last reply Reply Quote 0
                                    • lavolp3L Offline
                                      lavolp3 Module Developer @lavolp3
                                      @lavolp3 should be fixed now. Only one css line
                                      Again, please do a git pull
                                        matze86 @lavolp3
                                        @lavolp3
                                        I fixed it by my own
                                        I can send you the css of you want
                                        Is ist possible to delete the last games of my team?
                                        I only found a Solution to reduce it from 3 to 2 , by editing line 247 (changing the number in bracktes), but each other Number than 3 will only reduce it to 2 Games
                                        • lavolp3L Offline
                                          @matze86 Change line 249 in MMM-soccer.js from
                                          for (var i = index - 1; i < filteredMatches.length; i++) {
                                                              nextMatches.push(filteredMatches[i]);
                                          to
                                          for (var i = index; i < filteredMatches.length; i++) {
                                          (Remove the “- 1”)
                                            matze86 @lavolp3
                                            @lavolp3
                                            i changed it to “+ 1”, because with with i = index it will still display the last game. Or when will the module update the game list? i think on the next matchday?
                                            • 2 / 3
