    covid bell curve line graph tracker
    89 Posts 6 Posters 61.9k Views 8 Watching
    • bheplerB Offline
      bhepler Module Developer @sdetweil
      @sdetweil - Yeah… except 0.0.0.0 doesn’t work. So… what can you do?
      I put the network IP of my pi in that field and then connect to that IP address if I’m ever on the pi itself.
        sdetweil @bhepler
        @bhepler 0.0.0.0 works for me on multiple systems without problem
        And ipWhitelist:[],
          almostgithub @rafaelcota
          @rafaelcota Strange i am also having the same exact problem. My PI was also set to 0.0.0.0, however i changed it to localhost, and even tried its actual IP address as well and it did not fix it. I can change the height but not the width at all. I also tried placing it in other places on my mirror, as well as deleting the white space too
            sdetweil @almostgithub
            @almostgithub weird… I have 6 different systems running the module, ALL have address:“0.0.0.0”, ipWhiteList:[],
            and I cannot reproduce the problem.
            do another git pull… I just force commented out the inline-block statement that should never have been executed… see if it makes a difference
            rafaelcotaR A 2 Replies Last reply Reply Quote 0
            • rafaelcotaR Offline
              rafaelcota @sdetweil
              @sdetweil Nope… didn’t work, it just don’t work with address 0.0.0.0, only with localhost as address…it’s really weird…
              I’m using VNC to see my mirror remotely since it can’t be access from any other device… no problem for me, but my curious mind wonder how this can be.
              Thank you for your time and concern,
                sdetweil @rafaelcota
                @rafaelcota can u try something… address:“0.0.0.0”,
                and then open a separate browser to the pi address:port
                so you will have the vnc window and the browser window open at the same time to the same server
                f11 to toggle the browser to full screen and back
                  almostgithub @sdetweil
                  Did another Git pull and my graph is still off the screen. Looks like there is a lot of space in between each date on the graph.
                    @almostgithub make sure these two lines are commented out in MyCovid19.js, approx line 180
                            if ((canvas = document.getElementById("myChart"+self.ourID )) == null) {
                              var c = document.createElement("div");
                              c.style.width = self.config.width + "px";
                              c.style.height = self.config.height + "px";
                             // if (!self.config.stacked)                                           // < ----
                             //   c.style.display = 'inline-block';                            // < ----
                              self.wrapper.appendChild(c);
                      @sdetweil Those are both commented out. Is there anything else that may perhaps cause each date to be almost an inch apart? I may just do a fresh install to negate any other settings I may have tweaked with, but strange that @rafaelcota had a similar problem as well
                        @almostgithub could u confirm that the div still has display=inline-block, when u look thru the elements…
                        • 6
                        • 7
                        • 8
                        • 9
                        • 6 / 9
