    covid bell curve line graph tracker
    89 Posts 6 Posters 73.5k Views 8 Watching
      sdetweil @almostgithub
      @almostgithub lets try some new debugging
      git clone again, make sure debug:true, in each MyCovid19 module def in config.js
      the update now only downloads the data file ONCE across all the modules (1 for countries, 1 for states if both used)
      add this module
      git clone https://github.com/sdetweil/MMM-Logging
      add it to the TOP of the module list like this
      	modules: [    // < top of module list
                  module: 'MMM-Logging',
                  disabled: false,
                      // Module functions out of the box with nothing set here.
                      // See below for configurable options.
                      echoLocal: true,
                      echoRemote: true,
                      format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
      start MM like this from a terminal window (make sure to stop the pm2 one if u use pm2)
      cd ~/MagicMirror
      npm start >>somefile.txt 2>&1
      run your test with 0.0.0.0
      please test both on system and remote browser access
      ctrl-c to stop
      change to localhost
      restart same command
      ctrl-c when done
      send me somefile.txt at my email sdetweil at gmail
      rafaelcotaR 1 Reply Last reply Reply Quote 0
      • rafaelcotaR Offline
        rafaelcota @sdetweil
        @sdetweil You’re great, man. You’ve been working with MyCovid19 to fix the bug, a weird and difficult one to identify; you’ve done tests, modifications, sent me instructions how to debug, and more modifications, and tests, and debugging; and files and emails went between us and finally, I can say IT WORKS just fine!
        Address is 0.0.0.0, so I can access it from any device at port 8080 and graphs are just the size I put in config.
        Thank you again for all your time, effort and concern.
        Stay safe
          sdetweil @rafaelcota
          @rafaelcota glad we found it… now I gotta fix another toughie…
          • H Offline
            humdinger44
            I’ve been keeping an eye on the NY data so i can compare it to my home state. Any idea whats happened there? It might be nice to have a 7 day rolling average option to smooth the data out. If that’s within the realm of “Not very difficult.”
              sdetweil @humdinger44
              @humdinger44 i see it too… will mess up the charts for a while… boooo
              from the data source
              **NEW:** Starting with data for May 6th, this data reports the total combined number of confirmed and
              probable Covid-19 cases and deaths where available. Many states and localities have started to report this
              data using criteria that were developed by states and the federal government.
              This will cause a spike in the cases and deaths data for some areas while we work to revise our historical data
               with those probable cases and deaths.
                sdetweil
                I posted an update to github today,
                supports displaying US state county data
                a little bit trickier on the data entry
                counties:[ { ‘county_name’ : ‘state_name’ }, { ‘county_name2’ : ‘state_name2’} ]
                on the chart only the county name is shown
                  darbos
                  HI guys, thanks for making this! I am trying to show daily totales, I was trying to make it easy to see the totals for each day. However the graph is starting extremly high, see below. Can someone see what I am doing wrong?
                  THanks !
                  			module:"MyCovid19",
                  			position:"bottom_center",
                  			config:{
                  				states:['Arizona','Michigan','California'],
                  				line_colors:['red','white','blue'],
                  				chart_type:"cases",
                  				chart_title:"COVID Cases Reported Daily",
                  				ranges:{min:0,max:000,stepSize:100},
                                  backgroundColor: "transparent",
                  			    width: 600,
                  			    height: 500,
                  			    debug: true,
                  			    startDate: '06/01/2020'
                  ![Screenshot_20200616_185855.png](/assets/uploads/files/1592359395744-screenshot_20200616_185855.png)
                    sdetweil @darbos
                    @darbos max is 0???
                    D 3 Replies Last reply Reply Quote 0
                      darbos @sdetweil
                      @sdetweil I had it set at a higher number but took that from an example I found on here. What should those be set at? Ty
                        darbos @sdetweil
                        @sdetweil my goal is really to be able to look and see the daily totals for the past few days.
                          darbos @sdetweil
                          This is the big initial spike i dont know how to get rid of. Sorry last attachment wouldnt work.
                            sdetweil @darbos
                            @darbos I would start with a step of 50 and a max of 50. if the numbers are higher the chart engine will auto adjust.
                            if U have too many ticks on the left axis, then make the step higher (100) and raise the max to 100
                              sdetweil @darbos
                              @darbos for the spike, move the start day to the 2nd or 3rd
                                @sdetweil here is my cases by day by state
                                min 0, max 500, step 500
                                (chart 300x300)
                                one cool thing, when u make the step low, u can turn off individual sources to see the remaining adjust
                                just click on the legend entry to turn it off
                                looks like Michigan had a reporting spike
                                  sdetweil
                                  Looks like the EU site used for the data is currently down
                                    darbos @sdetweil
                                    @sdetweil Sorry for just getting back. Thanks for taking the time to explain and help.
                                    I follow what your saying and made the changes. Looks like the reporting site is down so I will have to wait to make sure mine looks as good as yours:)
                                    Thanks again.
                                      darbos @sdetweil
                                      @sdetweil Would you mind double checking my config, Im still seeing a large spike at the begining…
                                      Ive tried changing the start date to the 3rd, 10th, and 12th with the same result. Ive also tried both 0,100,100 and 0,500,500.
                                      Thank you much!
                                      		module:"MyCovid19",
                                      		config:{
                                      			chart_type:"cases",
                                      			ranges:{min:0,max:500,stepSize:500},
                                      		      width: 600,
                                      		      height: 500,
                                      		      debug: false,
                                      		      startDate: '06/12/2020'
                                      ***EDIT: The copy/paste spacing is off, but I double checked and spacing is correct in my file…with no trailing white space.
                                        darbos @sdetweil
                                        @sdetweil Its like its pulling the total first and then displaying dailys no matter what date I start at…I think anyway.
                                          sdetweil @darbos
                                          @darbos I see the same will debug later tonight. family dinner first
                                            darbos @sdetweil
                                            @sdetweil ok thank you much!!!
                                            • 4 / 5
