    covid bell curve line graph tracker
    89 Posts 6 Posters 75.2k Views 8 Watching
      sdetweil @bhepler
      @bhepler 0.0.0.0 works for me on multiple systems without problem
      And ipWhitelist:[],
      • A
        almostgithub @rafaelcota
        @rafaelcota Strange i am also having the same exact problem. My PI was also set to 0.0.0.0, however i changed it to localhost, and even tried its actual IP address as well and it did not fix it. I can change the height but not the width at all. I also tried placing it in other places on my mirror, as well as deleting the white space too
          sdetweil @almostgithub
          @almostgithub weird… I have 6 different systems running the module, ALL have address:“0.0.0.0”, ipWhiteList:[],
          and I cannot reproduce the problem.
          do another git pull… I just force commented out the inline-block statement that should never have been executed… see if it makes a difference
          rafaelcotaR A 2 Replies Last reply
          • rafaelcotaR
            rafaelcota @sdetweil
            @sdetweil Nope… didn’t work, it just don’t work with address 0.0.0.0, only with localhost as address…it’s really weird…
            I’m using VNC to see my mirror remotely since it can’t be access from any other device… no problem for me, but my curious mind wonder how this can be.
            Thank you for your time and concern,
              sdetweil @rafaelcota
              @rafaelcota can u try something… address:“0.0.0.0”,
              and then open a separate browser to the pi address:port
              so you will have the vnc window and the browser window open at the same time to the same server
              f11 to toggle the browser to full screen and back
              • A
                almostgithub @sdetweil
                Did another Git pull and my graph is still off the screen. Looks like there is a lot of space in between each date on the graph.
                  @almostgithub make sure these two lines are commented out in MyCovid19.js, approx line 180
                          if ((canvas = document.getElementById("myChart"+self.ourID )) == null) {
                            var c = document.createElement("div");
                            c.style.width = self.config.width + "px";
                            c.style.height = self.config.height + "px";
                           // if (!self.config.stacked)                                           // < ----
                           //   c.style.display = 'inline-block';                            // < ----
                            self.wrapper.appendChild(c);
                  A 1 Reply Last reply
                  • A
                    @sdetweil Those are both commented out. Is there anything else that may perhaps cause each date to be almost an inch apart? I may just do a fresh install to negate any other settings I may have tweaked with, but strange that @rafaelcota had a similar problem as well
                    S 2 Replies Last reply
                      @almostgithub could u confirm that the div still has display=inline-block, when u look thru the elements…
                        @almostgithub lets try some new debugging
                        git clone again, make sure debug:true, in each MyCovid19 module def in config.js
                        the update now only downloads the data file ONCE across all the modules (1 for countries, 1 for states if both used)
                        add this module
                        git clone https://github.com/sdetweil/MMM-Logging
                        add it to the TOP of the module list like this
                        	modules: [    // < top of module list
                                    module: 'MMM-Logging',
                                    disabled: false,
                                        // Module functions out of the box with nothing set here.
                                        // See below for configurable options.
                                        echoLocal: true,
                                        echoRemote: true,
                                        format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                        start MM like this from a terminal window (make sure to stop the pm2 one if u use pm2)
                        npm start >>somefile.txt 2>&1
                        run your test with 0.0.0.0
                        please test both on system and remote browser access
                        ctrl-c to stop
                        change to localhost
                        restart same command
                        ctrl-c when done
                        send me somefile.txt at my email sdetweil at gmail
                        rafaelcotaR 1 Reply Last reply
                        • rafaelcotaR
                          @sdetweil You’re great, man. You’ve been working with MyCovid19 to fix the bug, a weird and difficult one to identify; you’ve done tests, modifications, sent me instructions how to debug, and more modifications, and tests, and debugging; and files and emails went between us and finally, I can say IT WORKS just fine!
                          Address is 0.0.0.0, so I can access it from any device at port 8080 and graphs are just the size I put in config.
                          Thank you again for all your time, effort and concern.
                          Stay safe
                            @rafaelcota glad we found it… now I gotta fix another toughie…
                            • H
                              humdinger44
                              I’ve been keeping an eye on the NY data so i can compare it to my home state. Any idea whats happened there? It might be nice to have a 7 day rolling average option to smooth the data out. If that’s within the realm of “Not very difficult.”
                                sdetweil @humdinger44
                                @humdinger44 i see it too… will mess up the charts for a while… boooo
                                from the data source
                                **NEW:** Starting with data for May 6th, this data reports the total combined number of confirmed and
                                probable Covid-19 cases and deaths where available. Many states and localities have started to report this
                                data using criteria that were developed by states and the federal government.
                                This will cause a spike in the cases and deaths data for some areas while we work to revise our historical data
                                 with those probable cases and deaths.
                                  I posted an update to github today,
                                  supports displaying US state county data
                                  a little bit trickier on the data entry
                                  counties:[ { ‘county_name’ : ‘state_name’ }, { ‘county_name2’ : ‘state_name2’} ]
                                  on the chart only the county name is shown
                                    darbos
                                    HI guys, thanks for making this! I am trying to show daily totales, I was trying to make it easy to see the totals for each day. However the graph is starting extremly high, see below. Can someone see what I am doing wrong?
                                    THanks !
                                    			module:"MyCovid19",
                                    			position:"bottom_center",
                                    			config:{
                                    				states:['Arizona','Michigan','California'],
                                    				line_colors:['red','white','blue'],
                                    				chart_type:"cases",
                                    				chart_title:"COVID Cases Reported Daily",
                                    				ranges:{min:0,max:000,stepSize:100},
                                                    backgroundColor: "transparent",
                                    			    width: 600,
                                    			    height: 500,
                                    			    debug: true,
                                    			    startDate: '06/01/2020'
                                    ![Screenshot_20200616_185855.png](/assets/uploads/files/1592359395744-screenshot_20200616_185855.png)
                                      sdetweil @darbos
                                      @darbos max is 0???
                                      D 3 Replies Last reply
                                        darbos @sdetweil
                                        @sdetweil I had it set at a higher number but took that from an example I found on here. What should those be set at? Ty
                                          darbos @sdetweil
                                          @sdetweil my goal is really to be able to look and see the daily totals for the past few days.
                                            darbos @sdetweil
                                            This is the big initial spike i dont know how to get rid of. Sorry last attachment wouldnt work.
                                            • 4 / 5
