    covid bell curve line graph tracker
    89 Posts 6 Posters 73.8k Views 8 Watching
      sdetweil @rafaelcota
      @rafaelcota and I am running this particular test on a 1920x1080 ubuntu… but my pi4 is just behind me at 3840x2160
      • rafaelcotaR Offline
        rafaelcota @sdetweil
        It still there…
        I’m sure you have better things to do than debug this with a user… I’m going to do a clean install, even if it does mean to use the brand new MM version (don’t have much installed, and have lots of time nowadays) and see what happens…
        alt text
        S A 2 Replies Last reply Reply Quote 0
          @rafaelcota use my installer script
          see here
          rafaelcotaR 1 Reply Last reply Reply Quote 0
            @sdetweil Thank you…
            Used them… worked well.
            Did a clean install, use my old config and same thing happened.
            Change my config.js with original+MyCovid19 and ALL OK!
            So, I changed the original config.js with my modules, one by one and ALL went OK.
            So, I got curious, and then went to change the original config.js to my old one, module by module so I could find which one was interfering, and ALL went OK.
            UNTIL, and this is really strange, when I change the address of localhost at the beginning, it went to the same problem again.
            If I have address: “localhost”, ALL is OK
            If I have address: “0.0.0.0”, then the problem appears again.
            Any ideas?
            Here’s my mirror working OK
            alt text
            S B 2 Replies Last reply Reply Quote 0
              @rafaelcota said in covid bell curve line graph tracker:
              and
              ipWhitelist:[],
                @sdetweil I don’t understand how this parameters relate with the size of a graph.
                I think it’s weird, at least it kept me entertained for a couple of hours in quarantine. :)
                I hope you and your family and friends are OK.
                  @rafaelcota all ok here…
                  i have no idea really on the parms affecting… all my pi systems use address:“0.0.0.0” and ipWhitelist:[]
                  so I can open their pages on my pc at my desk. (easier to debug modules this way, run there , debug here)
                  i can only think that something in the chart.js library is trying to get a file or something and there is a cross site scripting restriction to stop it…
                    bhepler Module Developer @rafaelcota
                    Yeah, 0.0.0.0 is not the IP address of your Pi. If you don’t want to use localhost, try the IP address of your Pi on your local network instead. (you can find the local IP address by entering ip address from your Pi) The Magic Mirror framework is a web server at heart, so it needs to understand what IP address it is using. You can try 127.0.0.1 as well, as that is the “local loopback” IP address. It always points to itself.
                      sdetweil @bhepler
                      @bhepler no… 0.0.0.0 means listen on any/all physical network interfaces (wireless AND ethernet
                      127.0.0.1 means listen ONLY on the loopback interface … means ONLY apps INSIDE this same machine can access the url … (another browser for example)…
                      remote-control from your PC cannot connect
                      ip_address, means listen ONLY on the interface with that address (ie, listen on wireless or ethernet, not both)
                        bhepler Module Developer @sdetweil
                        @sdetweil - Yeah… except 0.0.0.0 doesn’t work. So… what can you do?
                        I put the network IP of my pi in that field and then connect to that IP address if I’m ever on the pi itself.
                          sdetweil @bhepler
                          @bhepler 0.0.0.0 works for me on multiple systems without problem
                          And ipWhitelist:[],
                            almostgithub @rafaelcota
                            @rafaelcota Strange i am also having the same exact problem. My PI was also set to 0.0.0.0, however i changed it to localhost, and even tried its actual IP address as well and it did not fix it. I can change the height but not the width at all. I also tried placing it in other places on my mirror, as well as deleting the white space too
                              sdetweil @almostgithub
                              @almostgithub weird… I have 6 different systems running the module, ALL have address:“0.0.0.0”, ipWhiteList:[],
                              and I cannot reproduce the problem.
                              do another git pull… I just force commented out the inline-block statement that should never have been executed… see if it makes a difference
                              rafaelcotaR A 2 Replies Last reply Reply Quote 0
                                @sdetweil Nope… didn’t work, it just don’t work with address 0.0.0.0, only with localhost as address…it’s really weird…
                                I’m using VNC to see my mirror remotely since it can’t be access from any other device… no problem for me, but my curious mind wonder how this can be.
                                Thank you for your time and concern,
                                  @rafaelcota can u try something… address:“0.0.0.0”,
                                  and then open a separate browser to the pi address:port
                                  so you will have the vnc window and the browser window open at the same time to the same server
                                  f11 to toggle the browser to full screen and back
                                    almostgithub @sdetweil
                                    Did another Git pull and my graph is still off the screen. Looks like there is a lot of space in between each date on the graph.
                                      @almostgithub make sure these two lines are commented out in MyCovid19.js, approx line 180
                                              if ((canvas = document.getElementById("myChart"+self.ourID )) == null) {
                                                var c = document.createElement("div");
                                                c.style.width = self.config.width + "px";
                                                c.style.height = self.config.height + "px";
                                               // if (!self.config.stacked)                                           // < ----
                                               //   c.style.display = 'inline-block';                            // < ----
                                                self.wrapper.appendChild(c);
                                        @sdetweil Those are both commented out. Is there anything else that may perhaps cause each date to be almost an inch apart? I may just do a fresh install to negate any other settings I may have tweaked with, but strange that @rafaelcota had a similar problem as well
                                          @almostgithub could u confirm that the div still has display=inline-block, when u look thru the elements…
                                            @almostgithub lets try some new debugging
                                            git clone again, make sure debug:true, in each MyCovid19 module def in config.js
                                            the update now only downloads the data file ONCE across all the modules (1 for countries, 1 for states if both used)
                                            add this module
                                            git clone https://github.com/sdetweil/MMM-Logging
                                            add it to the TOP of the module list like this
                                            	modules: [    // < top of module list
                                                        module: 'MMM-Logging',
                                                        disabled: false,
                                                            // Module functions out of the box with nothing set here.
                                                            // See below for configurable options.
                                                            echoLocal: true,
                                                            echoRemote: true,
                                                            format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                                            start MM like this from a terminal window (make sure to stop the pm2 one if u use pm2)
                                            npm start >>somefile.txt 2>&1
                                            run your test with 0.0.0.0
                                            please test both on system and remote browser access
                                            ctrl-c to stop
                                            change to localhost
                                            restart same command
                                            ctrl-c when done
                                            send me somefile.txt at my email sdetweil at gmail
                                            • 3 / 5
