    covid bell curve line graph tracker
    89 Posts 6 Posters 75.2k Views 8 Watching
      sdetweil @rafaelcota
      @rafaelcota said in covid bell curve line graph tracker:
      If I have address: “localhost”, ALL is OK
      If I have address: “0.0.0.0”, then the problem appears again.
      and
      ipWhitelist:[],
      rafaelcotaR 1 Reply Last reply
      • rafaelcotaR
        rafaelcota @sdetweil
        @sdetweil I don’t understand how this parameters relate with the size of a graph.
        I think it’s weird, at least it kept me entertained for a couple of hours in quarantine. :)
        I hope you and your family and friends are OK.
          @rafaelcota all ok here…
          i have no idea really on the parms affecting… all my pi systems use address:“0.0.0.0” and ipWhitelist:[]
          so I can open their pages on my pc at my desk. (easier to debug modules this way, run there , debug here)
          i can only think that something in the chart.js library is trying to get a file or something and there is a cross site scripting restriction to stop it…
            bhepler Module Developer @rafaelcota
            @sdetweil Thank you…
            Yeah, 0.0.0.0 is not the IP address of your Pi. If you don’t want to use localhost, try the IP address of your Pi on your local network instead. (you can find the local IP address by entering ip address from your Pi) The Magic Mirror framework is a web server at heart, so it needs to understand what IP address it is using. You can try 127.0.0.1 as well, as that is the “local loopback” IP address. It always points to itself.
              sdetweil @bhepler
              @bhepler no… 0.0.0.0 means listen on any/all physical network interfaces (wireless AND ethernet
              127.0.0.1 means listen ONLY on the loopback interface … means ONLY apps INSIDE this same machine can access the url … (another browser for example)…
              remote-control from your PC cannot connect
              ip_address, means listen ONLY on the interface with that address (ie, listen on wireless or ethernet, not both)
              B 1 Reply Last reply
                bhepler Module Developer @sdetweil
                @sdetweil - Yeah… except 0.0.0.0 doesn’t work. So… what can you do?
                I put the network IP of my pi in that field and then connect to that IP address if I’m ever on the pi itself.
                  sdetweil @bhepler
                  @bhepler 0.0.0.0 works for me on multiple systems without problem
                  And ipWhitelist:[],
                  • A
                    almostgithub @rafaelcota
                    @rafaelcota Strange i am also having the same exact problem. My PI was also set to 0.0.0.0, however i changed it to localhost, and even tried its actual IP address as well and it did not fix it. I can change the height but not the width at all. I also tried placing it in other places on my mirror, as well as deleting the white space too
                      sdetweil @almostgithub
                      @almostgithub weird… I have 6 different systems running the module, ALL have address:“0.0.0.0”, ipWhiteList:[],
                      and I cannot reproduce the problem.
                      do another git pull… I just force commented out the inline-block statement that should never have been executed… see if it makes a difference
                      rafaelcotaR A 2 Replies Last reply
                      • rafaelcotaR
                        @sdetweil Nope… didn’t work, it just don’t work with address 0.0.0.0, only with localhost as address…it’s really weird…
                        I’m using VNC to see my mirror remotely since it can’t be access from any other device… no problem for me, but my curious mind wonder how this can be.
                        Thank you for your time and concern,
                          @rafaelcota can u try something… address:“0.0.0.0”,
                          and then open a separate browser to the pi address:port
                          so you will have the vnc window and the browser window open at the same time to the same server
                          f11 to toggle the browser to full screen and back
                          • A
                            almostgithub @sdetweil
                            Did another Git pull and my graph is still off the screen. Looks like there is a lot of space in between each date on the graph.
                              @almostgithub make sure these two lines are commented out in MyCovid19.js, approx line 180
                                      if ((canvas = document.getElementById("myChart"+self.ourID )) == null) {
                                        var c = document.createElement("div");
                                        c.style.width = self.config.width + "px";
                                        c.style.height = self.config.height + "px";
                                       // if (!self.config.stacked)                                           // < ----
                                       //   c.style.display = 'inline-block';                            // < ----
                                        self.wrapper.appendChild(c);
                              A 1 Reply Last reply
                              • A
                                @sdetweil Those are both commented out. Is there anything else that may perhaps cause each date to be almost an inch apart? I may just do a fresh install to negate any other settings I may have tweaked with, but strange that @rafaelcota had a similar problem as well
                                S 2 Replies Last reply
                                  @almostgithub could u confirm that the div still has display=inline-block, when u look thru the elements…
                                    @almostgithub lets try some new debugging
                                    git clone again, make sure debug:true, in each MyCovid19 module def in config.js
                                    the update now only downloads the data file ONCE across all the modules (1 for countries, 1 for states if both used)
                                    add this module
                                    git clone https://github.com/sdetweil/MMM-Logging
                                    add it to the TOP of the module list like this
                                    	modules: [    // < top of module list
                                                module: 'MMM-Logging',
                                                disabled: false,
                                                    // Module functions out of the box with nothing set here.
                                                    // See below for configurable options.
                                                    echoLocal: true,
                                                    echoRemote: true,
                                                    format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                                    start MM like this from a terminal window (make sure to stop the pm2 one if u use pm2)
                                    npm start >>somefile.txt 2>&1
                                    run your test with 0.0.0.0
                                    please test both on system and remote browser access
                                    ctrl-c to stop
                                    change to localhost
                                    restart same command
                                    ctrl-c when done
                                    send me somefile.txt at my email sdetweil at gmail
                                    • rafaelcotaR
                                      @sdetweil You’re great, man. You’ve been working with MyCovid19 to fix the bug, a weird and difficult one to identify; you’ve done tests, modifications, sent me instructions how to debug, and more modifications, and tests, and debugging; and files and emails went between us and finally, I can say IT WORKS just fine!
                                      Address is 0.0.0.0, so I can access it from any device at port 8080 and graphs are just the size I put in config.
                                      Thank you again for all your time, effort and concern.
                                      Stay safe
                                        @rafaelcota glad we found it… now I gotta fix another toughie…
                                        • H
                                          humdinger44
                                          I’ve been keeping an eye on the NY data so i can compare it to my home state. Any idea whats happened there? It might be nice to have a 7 day rolling average option to smooth the data out. If that’s within the realm of “Not very difficult.”
                                            sdetweil @humdinger44
                                            @humdinger44 i see it too… will mess up the charts for a while… boooo
                                            from the data source
                                            **NEW:** Starting with data for May 6th, this data reports the total combined number of confirmed and
                                            probable Covid-19 cases and deaths where available. Many states and localities have started to report this
                                            data using criteria that were developed by states and the federal government.
                                            This will cause a spike in the cases and deaths data for some areas while we work to revise our historical data
                                             with those probable cases and deaths.
                                            • 3 / 5
