    covid bell curve line graph tracker
    89 Posts 6 Posters 75.2k Views 8 Watching
    • rafaelcotaR
      rafaelcota @sdetweil
      @sdetweil You’re great, man. You’ve been working with MyCovid19 to fix the bug, a weird and difficult one to identify; you’ve done tests, modifications, sent me instructions how to debug, and more modifications, and tests, and debugging; and files and emails went between us and finally, I can say IT WORKS just fine!
      Address is 0.0.0.0, so I can access it from any device at port 8080 and graphs are just the size I put in config.
      Thank you again for all your time, effort and concern.
      Stay safe
        sdetweil @rafaelcota
        @rafaelcota glad we found it… now I gotta fix another toughie…
        • H
          humdinger44
          I’ve been keeping an eye on the NY data so i can compare it to my home state. Any idea whats happened there? It might be nice to have a 7 day rolling average option to smooth the data out. If that’s within the realm of “Not very difficult.”
            sdetweil @humdinger44
            @humdinger44 i see it too… will mess up the charts for a while… boooo
            from the data source
            **NEW:** Starting with data for May 6th, this data reports the total combined number of confirmed and
            probable Covid-19 cases and deaths where available. Many states and localities have started to report this
            data using criteria that were developed by states and the federal government.
            This will cause a spike in the cases and deaths data for some areas while we work to revise our historical data
             with those probable cases and deaths.
              I posted an update to github today,
              supports displaying US state county data
              a little bit trickier on the data entry
              counties:[ { ‘county_name’ : ‘state_name’ }, { ‘county_name2’ : ‘state_name2’} ]
              on the chart only the county name is shown
                darbos
                HI guys, thanks for making this! I am trying to show daily totales, I was trying to make it easy to see the totals for each day. However the graph is starting extremly high, see below. Can someone see what I am doing wrong?
                THanks !
                			module:"MyCovid19",
                			position:"bottom_center",
                			config:{
                				states:['Arizona','Michigan','California'],
                				line_colors:['red','white','blue'],
                				chart_type:"cases",
                				chart_title:"COVID Cases Reported Daily",
                				ranges:{min:0,max:000,stepSize:100},
                                backgroundColor: "transparent",
                			    width: 600,
                			    height: 500,
                			    debug: true,
                			    startDate: '06/01/2020'
                ![Screenshot_20200616_185855.png](/assets/uploads/files/1592359395744-screenshot_20200616_185855.png)
                  sdetweil @darbos
                  @darbos max is 0???
                  D 3 Replies Last reply
                    darbos @sdetweil
                    @sdetweil I had it set at a higher number but took that from an example I found on here. What should those be set at? Ty
                      darbos @sdetweil
                      @sdetweil my goal is really to be able to look and see the daily totals for the past few days.
                        darbos @sdetweil
                        This is the big initial spike i dont know how to get rid of. Sorry last attachment wouldnt work.
                          sdetweil @darbos
                          @darbos I would start with a step of 50 and a max of 50. if the numbers are higher the chart engine will auto adjust.
                          if U have too many ticks on the left axis, then make the step higher (100) and raise the max to 100
                            sdetweil @darbos
                            @darbos for the spike, move the start day to the 2nd or 3rd
                              @sdetweil here is my cases by day by state
                              min 0, max 500, step 500
                              (chart 300x300)
                              one cool thing, when u make the step low, u can turn off individual sources to see the remaining adjust
                              just click on the legend entry to turn it off
                              looks like Michigan had a reporting spike
                              D 2 Replies Last reply
                                Looks like the EU site used for the data is currently down
                                D 1 Reply Last reply
                                  darbos @sdetweil
                                  @sdetweil Sorry for just getting back. Thanks for taking the time to explain and help.
                                  I follow what your saying and made the changes. Looks like the reporting site is down so I will have to wait to make sure mine looks as good as yours:)
                                  Thanks again.
                                    darbos @sdetweil
                                    @sdetweil Would you mind double checking my config, Im still seeing a large spike at the begining…
                                    Ive tried changing the start date to the 3rd, 10th, and 12th with the same result. Ive also tried both 0,100,100 and 0,500,500.
                                    Thank you much!
                                    		module:"MyCovid19",
                                    		config:{
                                    			chart_type:"cases",
                                    			ranges:{min:0,max:500,stepSize:500},
                                    		      width: 600,
                                    		      height: 500,
                                    		      debug: false,
                                    		      startDate: '06/12/2020'
                                    ***EDIT: The copy/paste spacing is off, but I double checked and spacing is correct in my file…with no trailing white space.
                                      darbos @sdetweil
                                      @sdetweil Its like its pulling the total first and then displaying dailys no matter what date I start at…I think anyway.
                                        sdetweil @darbos
                                        @darbos I see the same will debug later tonight. family dinner first
                                          darbos @sdetweil
                                          @sdetweil ok thank you much!!!
                                            sdetweil @darbos
                                            @darbos nice bug, been there since the beginning…
                                            the countries give me daily counts, and I have to calculate accumulative (1st day to last)
                                            the states/counties give me cumulative and I have to calculate dailys… (last day to 1st)…
                                            but I had cut off the number of days to the start date, and needed ONE more day to calculate the daily for the requested start day
                                            didn’t see it before, because back in feb/march the accum for states as near 0
                                            thanks for the good recreate…
                                            do a git pull in the module folder and restart magic mirror
                                            • 4 / 5
