    Connection failure error
    3 Posts 2 Posters 602 Views 2 Watching
      sbonn13
      Hi all,
      Since I have update MM via git pull I always receive connection failures in the console after starting MM. I do not know if it is related with MM or just a coincidence. Whilst using start dev I have found no error.
      Does anybody have an idea about the root cause or how I can continue searching for this issue?
      [00:12:32.977] [LOG]    Connection failure
      [00:12:32.979] [LOG]    Connection failure
      [00:12:32.981] [LOG]    Connection failure
      … (repeating constantly)
      Thanks!
        sdetweil @sbonn13
        @sbonn13 is the connection failure report in the pm2 log?
          sdetweil @sbonn13
          @sbonn13 open a terminal window (ssh is ok too)
          do
          cd ~/MagicMirror/modules
          # search all module source for error string
          find . | grep -v node_modules | grep \.js$ | grep -i connection
          # search all module dependencies for error string
          find . | grep  node_modules | grep \.js$ | grep -i connection
