    Credentials being blocked?
    5 Posts 2 Posters 1.6k Views 3 Watching
    • F
      Fr8Trayne
      So I have many great modules on my Mirror that are working, but there are some that just sit in the loading state. I’ve followed each installation to a T, but nothing seems to be going through. I took a glance at the logs and it looks like there is a web security things not allowing those modules to fetch the data. I read somewhere that Electron has a web preference for security that needed to turned off? Is this a thing? If so, any tips?
      In any case not sure why none of these are updating.
        sdetweil @Fr8Trayne
        @Fr8Trayne tell me more, show some errors… module name, (the url being used … u can mangle the data when posting here, just keep the https://… web server name of the url
        • F
          Fr8Trayne
          This is what I’m getting
          Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                this app to unnecessary security risks.
          For more information and help, consult
          https://electronjs.org/docs/tutorial/security.
           This warning will not show up
          once the app is packaged.
          and this from the logs.
          roboto.css:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          main.css:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          socket.io.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          config.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          defaults.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          nunjucks.min.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          defaultmodules.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          translations.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          module.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          vendor.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          logger.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          class.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          translator.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          loader.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          socketclient.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          main.js:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
          Can you tell from this information? If not I can throw my whole config in and have you take a look and yes I am a newb at this. I’ve learned a lot but this part is a bit over my head at the moment. Google was not my friend as I couldn’t understand what to do with the information given. It seems like the only modules that aren’t working are those that require credentials like the MMM-Fitbit2 and MMM-Airtable
            sdetweil @Fr8Trayne
            @Fr8Trayne can u tell us more…
            what is the address: and port : set to ,
            and also the ipWhitelist: in config.js
            is the UI on the same machine as the server (just npm start)
            • F
              Fr8Trayne
              address: "0.0.0.0", // Address to listen on, can be:
              	port: 8080,
              	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.42", "::ffff:192.168.0.50"], // Set [] to allow all IP addresses
              	ipWhitelist:[],
              and yes the UI is on the same machine.
