    Blank Black screen after the last - 2.11 - update
    20 Posts 5 Posters 5.7k Views 4 Watching
      sdetweil @kondef
      @kondef r u using pm2 to start?
      If so do
      pm2 logs
      ctrl-c to exit
      Then npm start
      Also may need to open developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors…
      • K Offline
        kondef @sdetweil
        @sdetweil No i start manually npm start
          sdetweil @kondef
          @kondef so, you should open the dev window
          • K Offline
            kondef @sdetweil
            @sdetweil You mean npm run start dev ? I am sorry i told you i am not expert. By pressing Control - Shift - i the only thing happens is a small window opens.
              sdetweil @kondef
              @kondef should be the right side of screen
              npm start dev can do the same on startup
              • K Offline
                kondef
                I am getting “DevTools was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect” and the page now is white blank and thre is nothing on the dev console.
                But i managed to take a photo while magic mirror was loading and i got the following: "MODULE NOT FOUND. Require Stack /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
                /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                /home/pi/MagicMirror/js/app.js
                /home/pi/MagicMirror/js/electron.js
                /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.
                  sdetweil @kondef
                  @kondef images don’t post…
                  • K Offline
                    kondef @sdetweil
                    Please note that i already did npm install on Hotword module
                      sdetweil @kondef
                      @kondef yeh, hotword needs an electron-rebuild I think
                      • K Offline
                        kondef @sdetweil
                        @sdetweil How? I tried to update snowboy but i am getting an error.
