    Calendar Module: 46 minutes = "in 1 hour": How to change the way relative time is shown?
    4 Posts 2 Posters 622 Views 2 Watching
    • T Offline
      todsandberg
      Appointment starts in X minutes [how can we adjust what is shown? and when it switches from hours to minutes]
      I would like to change magic mirror settings to show relative time is displayed in the calendar module.
      I have spent 1-2 hours trying things to solve this, seemingly simple, challenge, without a solution yet. Are you able to solve it?
      Example:
      • Current time is 11:43
      • Appointment at 12:30
      Current state:
      • Appointment starts in 1 hour (even though it is LESS than 1 hour)
      Desired behavior:
      • Appointment starts in 47 minutes
      It seems like this moment setting holds the key, but I haven’t been able to get it to work. (or find the right file location (or setting)to change)
      moment.relativeTimeThreshold(‘s’, 40);
      “Bonus points” for a solution that shows relative time to work with minutes >60… (example: 90 minutes left or 1h 30m left)
      Any help is greatly appreciated!
        sdetweil @todsandberg
        @todsandberg well, its here in calendar.js. line 329-331
         							if (event.startDate - now < this.config.getRelative * oneHour) {
        								// If event is within 6 hour, display 'in xxx' time format or moment.fromNow()
        								timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow());
        fixed up i think
        var m = moment(event.startDate, "x")
        if(this.config.timeThreshold!=undefined){
        m.relativeTimeThreshold(
        this.config.timeThreshold.unit,
        this.config.timeThreshold.limit);
        								timeWrapper.innerHTML = this.capFirst(m.fromNow());
        with the config item
        timeThreshold: {unit:minutes,limit:55},
        altho to get the right formatting, it might take overriding the fromNow method
        like this (for example, from https://stackoverflow.com/questions/41508796/moment-js-how-to-use-fromnow-to-return-everything-in-hours)
        moment.fn.fromNow = function (a) {
            var duration = moment().diff(this, 'hours');
            return duration;
        • T Offline
          todsandberg
          @sdetweil said in Calendar Module: 46 minutes = "in 1 hour": How to change the way relative time is shown?:
          Thank you, I have tried your code and will keep trying to get it to work.
            @todsandberg does it make any diffference?
