Holiday Calendar Won't Display with Other Calendars
Hello,
I’ve been running MM for a few days now. I have 3 calendars I’d like to display: US holidays, personal (google), and work (outlook). Everything worked fine initially but I recently saw that the holiday calendar does not display with the other two calendars. I investigated this by deleting the other two calendars and then the holiday calendar does work just fine on its own. But when I add the other two calendars back in, the holiday calendar does not display. Any help to get all 3 calendars shown appreciated! Here is my config snipet:{ module: 'calendar', position: 'top_left', config: { urgency: 0, getRelative: 0, fadePoint: 0.2, calendars: [ { symbol: 'calendar-check-0', url: 'http://www.calendarlabs.com/templates/ical/US-Holidays.ics' }, { symbol: 'calendar', url: 'https://calendar.google.com/xxxxxxxmy_personal_calendar.ics' }, { symbol: 'calendar', url: 'webcal://outlook.xxxxxxxxxxmy_work_calendar.ics' }, ], } }, -
@ljcwalston i replied to your other post a few minutes ago… please don’t make multiple posts for the same trouble
@sdetweil Does this mean the connection errors should resolve on their own? Is there something I can do to get them to display? I deleted the other thread as it seems this is a better place to ask.
@ljcwalston i replied to your other post a few minutes ago… please don’t make multiple posts for the same troublehow do you start mm? pm2? then
pm2 logs --lines=??will show the console log info where I see my errors
?? is a number, default is 15 lines, u may need to show more than 100
I have not looked at the code, so don’t know how it will do at network error recovery,
looks like it tries, based on the error messages
