    Sometimes Black Screen after upgrade to 2.11.0
    3 Posts 2 Posters 592 Views 1 Watching
    • M
      M_M
      Hi!
      I’m very new to MM2 and had the MM2 running for 2-3 weeks without problems.
      But after the update to 2.11.0 the MM2 starts sometimes with black screen.
      Here ist the output of the logfiles:
      /home/pi/.pm2/logs/mm-out.log
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      [2020-04-10 07:06:04.275] [LOG]    Starting MagicMirror: v2.11.0
      [2020-04-10 07:06:04.322] [LOG]    Loading config ...
      [2020-04-10 07:06:04.336] [LOG]    Loading module helpers ...
      [2020-04-10 07:06:04.340] [LOG]    No helper found for module: alert.
      [2020-04-10 07:06:04.460] [LOG]    Initializing new module helper ...
      [2020-04-10 07:06:04.461] [LOG]    Module helper loaded: updatenotification
      [2020-04-10 07:06:04.464] [LOG]    No helper found for module: clock.
      [2020-04-10 07:06:05.408] [LOG]    Initializing new module helper ...
      [2020-04-10 07:06:05.409] [LOG]    Module helper loaded: MMM-MyCalendar
      [2020-04-10 07:06:06.272] [LOG]    Initializing new module helper ...
      [2020-04-10 07:06:06.273] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
      [2020-04-10 07:06:07.295] [LOG]    Initializing new module helper ...
      [2020-04-10 07:06:07.300] [LOG]    Module helper loaded: MMM-DarkSkyForecast
      [2020-04-10 07:06:07.717] [LOG]    Initializing new module helper ...
      [2020-04-10 07:06:07.718] [LOG]    Module helper loaded: MMM-CalendarExt2
      [2020-04-10 07:06:07.859] [LOG]    Initializing new module helper ...
      [2020-04-10 07:06:07.860] [LOG]    Module helper loaded: MMM-Bring
      [2020-04-10 07:06:07.942] [LOG]    Initializing new module helper ...
      [2020-04-10 07:06:07.943] [LOG]    Module helper loaded: newsfeed
      [2020-04-10 07:06:07.943] [LOG]    All module helpers loaded.
      [2020-04-10 07:06:08.257] [LOG]    Starting server on port 8080 ...
      [2020-04-10 07:06:08.286] [LOG]    Server started ...
      [2020-04-10 07:06:08.287] [LOG]    Connecting socket for: updatenotification
      [2020-04-10 07:06:08.289] [LOG]    Connecting socket for: MMM-MyCalendar
      [2020-04-10 07:06:08.290] [LOG]    Starting node helper for: MMM-MyCalendar
      [2020-04-10 07:06:08.291] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
      [2020-04-10 07:06:08.292] [LOG]    MMM-DWD-WarnWeather helper started...
      [2020-04-10 07:06:08.293] [LOG]    Connecting socket for: MMM-DarkSkyForecast
      [2020-04-10 07:06:08.294] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      [2020-04-10 07:06:08.295] [LOG]    Connecting socket for: MMM-CalendarExt2
      [2020-04-10 07:06:08.297] [LOG]    Connecting socket for: MMM-Bring
      [2020-04-10 07:06:08.298] [LOG]    Connecting socket for: newsfeed
      [2020-04-10 07:06:08.299] [LOG]    Starting module: newsfeed
      [2020-04-10 07:06:08.300] [LOG]    Sockets connected & modules started ...
      [2020-04-10 07:06:08.833] [LOG]    Launching application.
      /home/pi/.npm/_logs/2020-04-09T06_07_27_758Z-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.13.4
      3 info using node@v10.19.0
      5 info lifecycle magicmirror@2.11.0~prestart: magicmirror@2.11.0
      6 info lifecycle magicmirror@2.11.0~start: magicmirror@2.11.0
      7 verbose lifecycle magicmirror@2.11.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.11.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.11.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.11.0~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 silly lifecycle magicmirror@2.11.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.11.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.11.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.97-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v10.19.0
      19 verbose npm  v6.13.4
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.11.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      When I try to start the MM2 2-3 times the black screen goes away and the MM2 is running normal.
      I don’t know much about npm so I’m totally lost.
      Maybe someone have an idea what I can try to solve this problem.
      Marcus
        sdetweil @M_M
        @M_M said in Sometimes Black Screen after upgrade to 2.11.0:
        does it make a difference whether the pm2 start is done by boot or from a terminal window after logon
        did you use my automated installer?
        if so do this
        pm2 stop 0
        pm2 delete 0
        pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
        if doing this over ssh or vnc, skip next step
            alt-spacebar, n to minimze MagicMirror to get back to terminal window
        pm2 save
        then redo your start testing
        • M
          M_M
          Hi Sam!
          Thank you for your support!
          Unfortunately all my last tries were not successful.
          Even your upgrade scripts with apply and force…
          So I decided to start from scratch.
          I removed/purged nodejs completly from the system and installed all new.
          Now it is running as it should.
          Don’t know what it was and I hope that this will not come back by the next upgrade…
          Marcus
