    MMM-AssistantMk2 - Google not responding
    6 Posts 2 Posters 960 Views 2 Watching
    • P Offline
      PP
      I have setup the Pi4 (latested version) with a ReSpeaker4 as mic. When I ask ‘SmartMirror’ the google interface showsup and then it stops. I receive the following message;
      [2020-04-12 07:54:43.762] [LOG] [HOTWORD] Detected: SMARTMIRROR
      [2020-04-12 07:54:44.024] [LOG] [HOTWORD] After Recording: 8000
      [2020-04-12 07:54:44.271] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:44.287] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:44.512] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:44.526] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:44.765] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:44.780] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:45.035] [LOG] [HOTWORD] After Recording: 8000
      [2020-04-12 07:54:45.265] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:45.276] [LOG] [HOTWORD] After Recording: 4000
      [2020-04-12 07:54:46.509] [LOG] [HOTWORD] stops.
      [2020-04-12 07:54:46.512] [LOG] [HOTWORD] After Recording finised. size: 48050
      [2020-04-12 07:54:46.516] [LOG] [HOTWORD:B2W] WAV_FILE_CREATED: /home/pi/MagicMirror/modules/MMM-Hotword/temp/afterRecording.wav 48050
      [2020-04-12 07:54:46.517] [LOG] [HOTWORD] Final Result: {
      detected: true,
      hotword: ‘SMARTMIRROR’,
      file: ‘temp/afterRecording.wav’
      [2020-04-12 07:54:47.085] [LOG] Whoops! There was an uncaught exception…
      [2020-04-12 07:54:47.086] [ERROR] TypeError [ERR_INVALID_ARG_TYPE] [ERR_INVALID_ARG_TYPE]: The “path” argument must be of type string. Received type undefined
      at validateString (internal/validators.js:107:11)
      at Object.resolve (path.js:978:7)
      at new ASSISTANT (/home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js:29:28)
      at Class.activateAssistant (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:86:22)
      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:37:14)
      at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
      at Socket.emit (events.js:200:13)
      at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
      at processTicksAndRejections (internal/process/task_queues.js:82:9)
      Does anyone know how to solve this?
      I allready tried to reinstall the complete Pi with a new version and all modules.
      • ? Offline
        A Former User
        hi, for this error,
        I think you don’t create your credentials.json file
        please read MMM-AssistantMk2 wiki for create it
        • P Offline
          PP
          The file is there and the test is working. Even the google screen pops up.
          • ? Offline
            A Former User
            in a terminal, can you try this:
            cd ~/MagicMirror/modules/MMM-AssistantMk2
            ls -la
            and give me the result please
            • P Offline
              PP @Guest
              It have reinstalled everything with the latest versions of today. I suppose the problem came during the adjustment of all the versions updates from the last couple of days. Thanks for your help.
              So a tip for all, never use duplicated modules from other people.
              • ? Offline
                A Former User
                perfect in this case ;)
