    eslint missing on new install
    3 Posts 2 Posters 491 Views
    • F
      fischershaw
      First time user.
      Used the detweiler script to install the latest version of MM (v2.11.0) on a fresh installation of Raspian (NOOBS v3.2.1). Ran “npm run config:check” which reports that eslint is missing. Running “npm install eslint” fixes this issue.
      Is this a MM issue or Detweiler script issue?
      S 2 Replies Last reply
        sdetweil @fischershaw
        @fischershaw it’s a script issue. I don’t install any of the development resources, to reduce space and also avoid install failures on armv6l systems.
        I’ll fix the scripts. Thanks
          @fischershaw I have pushed a fix for the two scripts, install and update…
          thanks for reporting the problem
          Reply Quote 1
