    Magic Mirror crashes on email module
    3 Posts 2 Posters 734 Views 2 Watching
    • F Offline
      FritsdeGroot
      I have an issue with my MagicMirror. I am new at this but I could not find a solution in the forum. Normally I would do a fresh install but the Magic Mirror is used by my 82 year old father and visiting him during the Coronacrisis is not advised. So I hope you can help me solve this form a distance.
      Platform: Rasperry Pi 3
      Node Version: v10.15.2
      Magic Mirror version: v2.11.0
      Description:
      After the upgrade of Magic Mirror via the script everything looked fine but since a couple of days the mm-error.log and mm-out.log get stashed with error messages. Eventually the system crashes as the filesystems get overloaded.
      The mm-out.log gives:
      [2020-04-22 12:25:55.646] [LOG]    Whoops! There was an uncaught exception...
      [2020-04-22 12:25:55.655] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-04-22 12:25:55.657] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-04-22 12:25:57.057] [LOG]    Email notifier error:  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
          at doWrite (_stream_writable.js:413:19)
          at clearBuffer (_stream_writable.js:543:7)
          at Socket.Writable.uncork (_stream_writable.js:321:7)
          at JSStreamSocket.doWrite (internal/js_stream_socket.js:162:17)
          at JSStream.onwrite (internal/js_stream_socket.js:20:57)
          at Socket.ondata (internal/js_stream_socket.js:64:22)
          at Socket.emit (events.js:200:13)
          at addChunk (_stream_readable.js:294:12)
          at readableAddChunk (_stream_readable.js:275:11)
          at Socket.Readable.push (_stream_readable.js:210:10) {
        source: 'socket'
      The mm-error.log gives:
      [2020-04-22 12:25:59.348] [ERROR]  Error: self signed certificate
          at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
          at TLSSocket.emit (events.js:200:13)
          at TLSSocket._finishInit (_tls_wrap.js:792:8)
          at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12)
          at TCP.onStreamRead (internal/stream_base_commons.js:166:17) {
        code: 'DEPTH_ZERO_SELF_SIGNED_CERT',
        source: 'socket'
      After I deactivated the email module the errors did not occur anymore. This is the section I used within the config.js
                              module: "email",
                              header: "Email",
                                      accounts: [
                                                      user: "g**********@gmail.com",
                                                      password: "**********",
                                                      host: "imap.gmail.com",
                                                      port: 993,
                                                      tls: true,
                                                      authTimeout: 10000,
                                                      numberOfEmails: 5,
                                      fade: false,
                                      maxCharacters: 50
      Thnx
      Frits
        sdetweil @FritsdeGroot
        @FritsdeGroot are u trying to run in https mode?
        can u send me the upgrade log?
        ~/MagicMirror/installers/upgrade.log
          @FritsdeGroot if you used this module https://github.com/ronny3050/email-mirror
          the upgrade script should have refreshed its dependencies (the upgrade log will show that)
